Bathroom Building
/ Bathroom Building #21
Simple and inexpensive is FRP from Home Depot, comes in 4 X 8 sheets, just caulk everything well.........
I used to live in San Diego also, miss it terribly...........
/ Bathroom Building #22
For simplicity and cost effectiveness why not just go with a pre-made fiberglass unit? Many can be attached directly to the studs. Add your drain and supply lines and your done.
/ Bathroom Building #23
Any chance you have a floor plan you could share with us?
I have a similar project coming up soon.
/ Bathroom Building
I thought about the fiberglass enclsosure but am a little closterphobic and need more space so when I poured the slab I put a drain in that is sloped so all I need to do is add the walls and a shower head.
I will come up with something that shows my floor plan idea when I get home.
The product from home depot sounds good, I have seen it at 22.00 a sheet which is cheap, I just wasn't sure about it being waterproof although it does say for showers right on it. The shower will be near the corner so I would only need a few sheets. I was going to wainscoat the bottom of the walls up to where the shower goes and use a thin solid wood panel for the top 4'of wall with a chair rail all the way around. White fixtures to match the wainscoating with a off tan pergo tile on the far end and some ceramic tile on the floor near the shower. Or just leave the floor as is.
San Diego is nice but you sure pay the price to live here.
/ Bathroom Building
I tried to find a better photo to show the floor plan. My Scanner is probably not functional so this is all I have.
I am standing just above and to the right of the shower. The entry door is to the far right in the photo. The Toilet is directly behind me and the vanity will go just to the left of the toilet in the photo. So both the shower and toilet are in oppisite corners on the same end of the building and the toilet is right next to the vanity so while your seated you can rest your magazine or news paper on the vanity. I will leave some space not to feel cramped I think 15 inches is normal.
So as you walk in the main doorway nothing is there every thing is positioned to the end wall with the toilet closer to the center of the wall behind me. The thinking was that this would give you plenty of room to take a shower, and get dressed. I will probably move my little dresser out there as well as a bench or something to sit on. The door will open out and away from the building.
One window is placed at the wall opposite the main door near the shower placed at 5' tall so you can look out but if someone looked in they couldn't see much. The other window is just to the right of the toilet and up about 4 and a half feet. I will put two more long rectangle windows on the wall behind me near the dressing area, they will be placed high as well and will fit between the studs.
/ Bathroom Building
Correction rectangle window will be on the wall in front of me the only wall not framed for windows, since they will fit between the studs.
/ Bathroom Building
Here is the floor plan
/ Bathroom Building #28
Are your drain lines in for those locations? If it was me, I'd move the sink to the other side of the toilet and next to the door. Just having a sink to wash up is very nice, but there's no need to go through the entire bathoom to get it. It's also nice to have lots of room in front of a shower to change clothes. A bench or seat along that wall would be very handy.
You will need an interior wall for the shower. I'd put the shower manifold on that interior wall too. I don't think it matters wich side you put it on, but I just like to have them on interior walls.
Where will the hot water heater go?
Do you have a place to store towels, soap and toilet paper?
Eddie
/ Bathroom Building #29
If you don't like that closed in feeling, go with glass. Here is my shower.
/ Bathroom Building
Harvester that is one nice bathroom. I am going to save that photo and use something like that in the new house.
Yea Eddie all the drain lines are in. I built a small vanity that shouldn't take up too much room and will have storage for towels and supplies underneath.
The water heater is small, direct on demand type. I think it's 20" x 20". I plan on putting it near the entry door on the same wall as the shower.
The shower floor is already sloped so I shouldn't need an enclosure or a ****. If I do need a **** I can put one in later. I had planned on simply putting in a curtain in that corner which would allow a person flexability on where the entered the shower. I can put a bench in just across from the toilet?
/ Bathroom Building #31
saltman said:
Since it looks like I am not going to be able to build my vacation house this spring I deceided to build a bathroom building to go with my small cabin so I have a place shower on the long weekends.
I poured a 8x12 slab with my new pto mixer and then framed it, next step this weekend is to hang the rafters and sheet it.
WOW!! What a view. Maybe you are used to it, but from Virginia those pictures are breathtaking.
/ Bathroom Building
I am not used to the view yet and really enjoy being out there. I live in town so I really appreciate the time I spend out there. I can't wait to get my house built some day soon.
Here are some more photos.
I guess it's what you appreciate, my mothers family is from the NW they don't really like the high desert, but I think it's really pretty.
/ Bathroom Building
Here they are.
/ Bathroom Building #34
Harvester,
That is some kind of fine shower/bath combo. Saved it cause I have a master suite to get planned and have been having the devil finding any plans for master bath plans.
/ Bathroom Building
I finally got a day during the week last week and got the t-111 put on and the two windows. I am going to make windows later that will fit between the studs on the one side so all sides will have a window if you count the door window.
/ Bathroom Building
I finished the roof sheating and did a little tractor work on area around the building. Next is the roofing, vent pipe, door installation, paint and window trim.
/ Bathroom Building #37
Thanks for the update and pics. Nice to see the progress and how the building it looking. That view is just amazing!!
Eddie
/ Bathroom Building
I finished the exterior of the bathroom building on Saturday morning, I only need to paint the trim and then I can start on the inside. It's been warm so the first thing I am going to do is insulate. Here are some photos of the nearly finised exterior, minus the final trim on one of the windows and trim paint.
I used my tractor extensivly on this project from the grading for the foundation, the mixing of cement, standing up the walls and the roofing and sheeting of the roof.
/ Bathroom Building #39
MAN! Way off topic but that last pick looks like a Scorpa Trials bike sitting there. You a Trials rider by chance?
/ Bathroom Building
Good eye, yes it's a Scorpa Long Ride Trials bike. I am not a "trials rider" more of a moto x guy but I like to trail ride on my trails bike and it's perfect country for it.
2004 Mack CH613 Concrete/ Water Mixer Truck (A64194)
2004 Mack CH613...
MechMaxx Grinder Betsco Flail mower
MechMaxx Grinder...
2020 CATERPILLAR 926M WHEEL LOADER (A65053)
2020 CATERPILLAR...
2025 HT360W Mini Stand-On Track Loader Skid Steer (A64553)
2025 HT360W Mini...
2004 Mack 613 Concrete Mixing Truck (A64194)
2004 Mack 613...
2022 EZ-GO ELITE...
