Bar oil quality
/ Bar oil quality #101
Same on the bar oil, run down to Madsen's pick it up. They usually have a pretty good price on it. I'll have to check out the pre mix next time i'm there.
My daughter bought a chainsaw, and a can of pre-mix gasoline.
She used the saw once, the pre-mix sat in the garage for over 5 years.
I brought the pre-mix home, and had it on a shelf, I was going to use it to light a brushfire,,,
Well, I had a small gas engine that would not start,, I knew I needed to prime the engine,, I remembered the pre-mix,,
I tossed a little premix in the carb, the engine started right up!! WOOT!!
It was sure easy using that small can of gasoline,, and it was perfect for starting that engine!!
/ Bar oil quality #102
Don't have a clue what Stihl uses for stabilizer but it sure looks like Marine Stabil. I do know the red stinky stuff is worthless.
I top off all my tanks in the fall and in the spring, they all fire tight up.
/ Bar oil quality #103
I just use the 15w40 drain oil that I have, works like a charm
Landhonor 3-Pt PTO Potato Harvester (A66285)
Landhonor 3-Pt PTO...
16ft. Aluminum Extension Ladder (A65640)
16ft. Aluminum...
2016 CATERPILLAR D6K2 LGP CRAWLER DOZER (A65053)
2016 CATERPILLAR...
2008 WELLS CARGO 16 ENCLOSED T/A TRAILER (A65643)
2008 WELLS CARGO...
2003 Odyssey Lextra 2502 Pontoon w/ 2009 Bagg Boat Trailer (A62613)
2003 Odyssey...
GREAT PLAINS 1006NT - 1575 NO-TILL GRAIN DRILL (A64277)
GREAT PLAINS...
