Bale Spear Build
/ Bale Spear Build #11
Looks like most farmer welding projects. Not real pretty but holds up just fine.
/ Bale Spear Build
Most of my stuff isn't much for looks I am happy as long as it holds together and does what I need from it. I do have a rattle can of JD Green for it after a little grinding and touch up i spots. I was in a hurry because I should have a load of hay any day now.
/ Bale Spear Build #13
Glad you are getting some work done in all this rain. I'm just SE of you and it has been dumping for the last 2 days and pretty much all farming and construction work has stopped.
/ Bale Spear Build
UPDATE:
Just finished unloading 39 #1100 bales with no issues. No evidence of weld pulling or any other problems. On a side note if anyone has experience with Fasse valves I am in need of help with mine. It seems to be bypassing under pressure. With the button pushed it activates but at a certain point instead of the grapple gripping the curl function activates.
Thanks,
Todd
2017 Case CX145D (A60462)
2017 Case CX145D...
2025 14ft. Bi-Parting Driveway Gate (A59231)
2025 14ft...
(INOP) JOHN DEERE 450CE CRAWLER DOZER (A59823)
(INOP) JOHN DEERE...
Giyi XKH39 (A60463)
Giyi XKH39 (A60463)
10ft. Inflatable Fire Rescue Boat (A59231)
10ft. Inflatable...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
