Bale Spear Build
/ Bale Spear Build #1
Todd NE WY
North East WY
JD 4320
I just thought I would share a recent project of mine. I haven't posted pictures of my projects before and I am open to anyone looking at the welds and offering suggestions. I built this to lift 1200# 3X4X8 bales of hay. My previous spear only had 2 tines about 40 inches apart and it was difficult to lift the bales because they would sag. So here is the 6' 5 tine improved model.
Todd
/ Bale Spear Build #2
Looks pretty darn good to me. :thumbsup: Are you gonna sleeve those spears so you can replace them easily? I wish I could weld so I could build one.
/ Bale Spear Build #3
Nice build ... May want a gusset on top of the JD hook I've seen them roll up. I think u could have keep the plate flat against the frame ... Either way a job well done !!!
/ Bale Spear Build
mjw357 yes the tines are sleeved, I took the picture of the attachment from the rear before I put the sleeves on.
blueriver yes I am going to gusset the top hooks, my snow blade has them reinforced so I will copy that. As far as the angle goes, I just copied my existing smaller bale spear and that is how it is. It allows the tines to go past parallel and tip down.
Thanks for the comments guys.
Todd
/ Bale Spear Build #8
Man go buy you a used stick welder for $150 and have some fun with welding!
Sooner you start, the sooner you get to practicing. :)
/ Bale Spear Build #9
You forgot to ask for $100 so you could mail him a certificate ;)
There's a perfect example of inflation. I got mine quite a few years ago for a buck and they even threw in a box of crackerjacks. :)
Terry
/ Bale Spear Build #11
Looks like most farmer welding projects. Not real pretty but holds up just fine.
/ Bale Spear Build
Most of my stuff isn't much for looks I am happy as long as it holds together and does what I need from it. I do have a rattle can of JD Green for it after a little grinding and touch up i spots. I was in a hurry because I should have a load of hay any day now.
/ Bale Spear Build #13
Glad you are getting some work done in all this rain. I'm just SE of you and it has been dumping for the last 2 days and pretty much all farming and construction work has stopped.
/ Bale Spear Build
UPDATE:
Just finished unloading 39 #1100 bales with no issues. No evidence of weld pulling or any other problems. On a side note if anyone has experience with Fasse valves I am in need of help with mine. It seems to be bypassing under pressure. With the button pushed it activates but at a certain point instead of the grapple gripping the curl function activates.
Thanks,
Todd
E-Z TRAIL HEADER CART (A63291)
E-Z TRAIL HEADER...
2020 Godfrey Marine Hurricane Boat w T/A Boat Trailer . (A61574)
2020 Godfrey...
Case skid steer wheels and tires (A63689)
Case skid steer...
2019 Terra Gator TG8400C Spreader (A63111)
2019 Terra Gator...
WILDKAT 78 ROCK GRAPPLE (A61572)
WILDKAT 78 ROCK...
2004 John Deere 8320 (A63688)
2004 John Deere...
