Balancing Front Tires?
/ Balancing Front Tires? #1
Woodsman30350
Texas
Montana 3040
I have a Montana 3040 with Industrial tires. I just replaced the front tires and was wondering if one needs to balance tractor tires as you would an automobile?
/ Balancing Front Tires? #2
I've never seen a wheel weight on a tractor......
I should probably clarify as I know someone will correct me..... :mur:
balancing wheel weights.....
Traction wheel weights used to be common place, but not so much any more
:drink:
/ Balancing Front Tires? #3
How fast you gonna drive this thing?
I dont imagine tractors go fast enough that balance would be an issue.
/ Balancing Front Tires? #5
Not enough speed to matter. Plus the tires would require so much weight they'd have a hard time doing it. The tires simply aren't built or designed with roundness and evenness as a high priority. Tractor tires are designed with big lugs, weight and durability in mind.
That is what I thought but I replaced the Titan Industrials on my Montana 3040 and they vibrate a little whereas the original tires did not when the tractor is in 4th gear on pavement.
/ Balancing Front Tires? #7
Maybe check the front end parts
If you have worn out a set of tires you may have some worn parts now
/ Balancing Front Tires? #8
It's likely the lugs and not the balance.
Front Tank Bracket (A64126)
Front Tank Bracket...
40ft 10 Door Shipping Container (A64194)
40ft 10 Door...
Kubota V3600-T Turbo Diesel Industrial Engine  63kW (84 HP)  2016 Model  Pump Takeout (A63689)
Kubota V3600-T...
2018 KAUFMAN 44 FT T/A  CAR CARRIER TRAILER (A59914)
2018 KAUFMAN 44 FT...
2008 R&R FLATBED WINCH TRAILER (A65643)
2008 R&R FLATBED...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
