Balancing Front Tires?
/ Balancing Front Tires? #1
Woodsman30350
Bronze Member
Texas
Montana 3040
I have a Montana 3040 with Industrial tires. I just replaced the front tires and was wondering if one needs to balance tractor tires as you would an automobile?
/ Balancing Front Tires? #2
I've never seen a wheel weight on a tractor......
I should probably clarify as I know someone will correct me..... :mur:
balancing wheel weights.....
Traction wheel weights used to be common place, but not so much any more
:drink:
/ Balancing Front Tires? #3
How fast you gonna drive this thing?
I dont imagine tractors go fast enough that balance would be an issue.
/ Balancing Front Tires? #5
Not enough speed to matter. Plus the tires would require so much weight they'd have a hard time doing it. The tires simply aren't built or designed with roundness and evenness as a high priority. Tractor tires are designed with big lugs, weight and durability in mind.
That is what I thought but I replaced the Titan Industrials on my Montana 3040 and they vibrate a little whereas the original tires did not when the tractor is in 4th gear on pavement.
/ Balancing Front Tires? #7
Maybe check the front end parts
If you have worn out a set of tires you may have some worn parts now
/ Balancing Front Tires? #8
It's likely the lugs and not the balance.
(2) 4 WAY WRENCHES (A64276)
(2) 4 WAY WRENCHES...
2000 Ford Windstar Van (A61574)
2000 Ford Windstar...
2009 IMPERIOAL DT7126T 12FT CUSTOM DUMP TRAILER (A66091)
2009 IMPERIOAL...
2021 Weber CF 2-IIHD Plate Compactor (A61572)
2021 Weber CF...
IH IC70-2 RUBBER TRACKED CRAWLER CARRIER (A65056)
IH IC70-2 RUBBER...
2012 Ford F-250 Crew Cab Pickup Truck (A64556)
2012 Ford F-250...
