Balancing Front Tires?
/ Balancing Front Tires? #1
Woodsman30350
Texas
Montana 3040
I have a Montana 3040 with Industrial tires. I just replaced the front tires and was wondering if one needs to balance tractor tires as you would an automobile?
/ Balancing Front Tires? #2
I've never seen a wheel weight on a tractor......
I should probably clarify as I know someone will correct me..... :mur:
balancing wheel weights.....
Traction wheel weights used to be common place, but not so much any more
:drink:
/ Balancing Front Tires? #3
How fast you gonna drive this thing?
I dont imagine tractors go fast enough that balance would be an issue.
/ Balancing Front Tires? #5
Not enough speed to matter. Plus the tires would require so much weight they'd have a hard time doing it. The tires simply aren't built or designed with roundness and evenness as a high priority. Tractor tires are designed with big lugs, weight and durability in mind.
That is what I thought but I replaced the Titan Industrials on my Montana 3040 and they vibrate a little whereas the original tires did not when the tractor is in 4th gear on pavement.
/ Balancing Front Tires? #7
Maybe check the front end parts
If you have worn out a set of tires you may have some worn parts now
/ Balancing Front Tires? #8
It's likely the lugs and not the balance.
2021 CATERPILLAR 299D3 XE SKID STEER (A65053)
2021 CATERPILLAR...
MILLER BOBCAT 250 PORTABLE ARC WELDER (A64276)
MILLER BOBCAT 250...
2023 Case 75c FarmAll Tractor (A62679)
2023 Case 75c...
3pt Hitch Receiver (A62679)
3pt Hitch Receiver...
Mini Skid Steer (A60352)
Mini Skid Steer...
Allis Chalmers 1200 Field Cultivator (A66408)
Allis Chalmers...
