Balancing Front Tires?
/ Balancing Front Tires? #1
Woodsman30350
Texas
Montana 3040
I have a Montana 3040 with Industrial tires. I just replaced the front tires and was wondering if one needs to balance tractor tires as you would an automobile?
/ Balancing Front Tires? #2
I've never seen a wheel weight on a tractor......
I should probably clarify as I know someone will correct me..... :mur:
balancing wheel weights.....
Traction wheel weights used to be common place, but not so much any more
:drink:
/ Balancing Front Tires? #3
How fast you gonna drive this thing?
I dont imagine tractors go fast enough that balance would be an issue.
/ Balancing Front Tires? #5
Not enough speed to matter. Plus the tires would require so much weight they'd have a hard time doing it. The tires simply aren't built or designed with roundness and evenness as a high priority. Tractor tires are designed with big lugs, weight and durability in mind.
That is what I thought but I replaced the Titan Industrials on my Montana 3040 and they vibrate a little whereas the original tires did not when the tractor is in 4th gear on pavement.
/ Balancing Front Tires? #7
Maybe check the front end parts
If you have worn out a set of tires you may have some worn parts now
/ Balancing Front Tires? #8
It's likely the lugs and not the balance.
New/Unused AGROTK Tire Changer (A65583)
New/Unused AGROTK...
2014 Jeep Wrangler 4x4 (MPV), VIN # 1C4BJWDGXEL206125 (A65579)
2014 Jeep Wrangler...
Volvo EC55B Exvacator (A62679)
Volvo EC55B...
2022 EZ-GO ELITE...
2020 KOMATSU D65EX-18 CRAWLER DOZER (A65053)
2020 KOMATSU...
2018 DRAGON  130BBL VACUUM TRAILER (A65643)
2018 DRAGON...
