Backing Up Computer Data Options???
/ Backing Up Computer Data Options??? #12
Tom,
I just bought a USB external Hard Disk as well as a DVD burner. Part of this decision to buy was based on burning DVDs of the kids from the video camera. I needed more disk space than I had in the system and decided the the exteranl system would be easier to insall and we can use it for other systems as well. I have a Western Digital which I think is a 250 GB. It was about $220.
Its real easy to install. If you can plug in a lamp you can do this. We just bought a smaller one for my dad. The software to back up is so so. I think it could be easier to use but it works. Well it seems to work. /forums/images/graemlins/grin.gif Since none of the systems have crashed I have not tried to restore yet. /forums/images/graemlins/grin.gif Which is a good thing.
So far no problems.
Later,
Dan
/ Backing Up Computer Data Options??? #13
PineRidge does what really should be done, but it is a bit complex for most home users. Backing up to a second hard drive in the same case is better than nothing, but it doesn't protect against data loss due to fire, lightning strike, or equipment theft, etc.
Probably one of the better solutions is a portable USB drive. Look for one powered off of the USB bus itself. These models are small, usually use laptop drives, which tend to be a bit more rugged than desktop models, and are small enough to carry around in your pocket.
Storing the backup drive in another structure, one that isn't likely to be involved in any "event" that might damage the primary drive, is a good idea.
/ Backing Up Computer Data Options??? #14
We have a raid array at work, and we back up financial data every day to tape, which we keep in a fireproof safe.
I think backing pictures, video and music to a DVD is a good idea - for now. But as formats change (my newer computer didn't even come with an "A" drive (3" floppy) - you may have to do it again some time in the future, so save that DVD player!
/ Backing Up Computer Data Options??? #15
For the typical home user, I think the USB external HD's are best. They are relatively inexpensive, super easy for anyone to set up (just plug it in) and can be bought with some pretty high capacities. The downsides are that they are slighter more expensive per gig of capacity and sometimes slower. But they are also extremely portable.
/ Backing Up Computer Data Options??? #16
I have one of these, 60 gig drive from a "trashed" laptop...so much for Toshiba support, and I think 15$ from Ebay seller for the case.
works great!
/ Backing Up Computer Data Options??? #17
You need four things
XPCGear.com
1. 3.5" hard drive enclosure 39.99
2. USB 2.0 or Firewire PCI card and cable 18.99 and 7.99
3. The biggest hard drive you can afford WD 200GB - 86.99
New Egg.com
4. Backup software (I like Acronis True Image) 29.99
$183.95 less shipping
But the WD backup solution in a box is not bad either.
/ Backing Up Computer Data Options??? #19
</font><font color="blue" class="small">( 4. Backup software (I like Acronis True Image) 29.99)</font>
Thanks for the recommendation; I just downlaoded the free trial version and am making an image of my C: drive now. I already had a Maxtor USB external hard drive, but the Windows XP backup software was poor and didn't like the FAT32 file system on the Maxtor. Acronis doesn't care, and looks like it will run in a fraction of the time that XP wanted to.
/ Backing Up Computer Data Options??? #20
Hi there Vernon
Can this mirror system be used on a network server or would there be issues with network software?
Cheers....Coffeeman
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
2021 Kubota RTV-X1140 4x4 Diesel Utility Cart (A59228)
2021 Kubota...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A61307)
Neckover GL24-2-7K...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
