$10K L5030 Plus Restoration, or $25K Newer Tractor With Perilous Electronics?
   / $10K L5030 Plus Restoration, or $25K Newer Tractor With Perilous Electronics?
You can definitely have it as long as you're single.
   / $10K L5030 Plus Restoration, or $25K Newer Tractor With Perilous Electronics? #42
The idea of running a tractor at very high RPM's to help the environment IS nutty. And it comes from the same people who want us to conserve everything, bathe rarely, and basically live in huts.
My L3710 runs very happily at 1500 RPM. If I had to run it at mowing speeds in order to do the regen Heimlich, it would be very annoying, and it would use more diesel and put more wear on the powertrain.
My decision about avoiding the emissions junk is not open to debate, and the more I hear about this stuff from people who actually work on tractors and trucks, the worse it sounds. I think a lot of people defend it because they already have it.
I’m not defending it I think it’s more reliable to not have it but my 2015 skid steer starts and works everyday so I’m not sure your 10 years to the scrap yard is a solid argument either.
I am paying more attention to the many people who have had expensive emissions-parts failures.
   / $10K L5030 Plus Restoration, or $25K Newer Tractor With Perilous Electronics? #44
The OP didn't tell the end of the story. I hope he didn't end up in the funny farm.
   / $10K L5030 Plus Restoration, or $25K Newer Tractor With Perilous Electronics? #46
Just on a footnote on TYM's, rather than under-building their axles I think the correct statement is the probably over built their lifting capacities vs green and orange. I have a tier 4 TYM T474 with a Onan\Cummins\Kukje\TYM derives A2300N4 engine. I have 600h without a regen or issue, I run it mostly above 2k rpm when I'm working it, and not idling for more than 5-10 minutes at most. Otherwise I'd just shut it off.
   / $10K L5030 Plus Restoration, or $25K Newer Tractor With Perilous Electronics? #47
Ok, not to go too far off on emissions Again... but part of the problem, Not all of it; is/was a change in mindset on running equipment. It used to be standard practice to start everything in the morning up, grease, fuel, and let it idle, for anything you would run before lunch. So, a vibratory rollers, might not need it till 10:30; but you started it at 7am, and let it idle; haul truck, pan, ect. The old philosophy was, fuels cheap, and it doesn't burn much idling, and if it's gonning to need jumped, or it has a problem, its better to know at the start of the day.
   / $10K L5030 Plus Restoration, or $25K Newer Tractor With Perilous Electronics? #48
That's not a problem with my wife, she's easy to get along with on my wishes.
But seeing as I already have 4 tractors just for my place as I don't do much at the farm anymore.
The IH 574 hasn't been disconnected from the pto generator in over a year. The Branson 8050 does my driveway work and trimming, the little Kioti 2620 does my puttering around digging and such, and the NH 8160 sits and waits most of the time for me to sand the driveway with her. Only put 5 hours on her this past year.
   / $10K L5030 Plus Restoration, or $25K Newer Tractor With Perilous Electronics? #49
I looked for a pre-emission for half a year - these are at least 13 years old now. Finally bought a 2015 L4760 (Kubota) and now have over 100 hours on it. Regenerations come around pretty quickly the way I use the tractor - 1,500 RPM usually and limited idling. If the particulate filter is good for 3,000 regens, and if I average 20 hours between regens, that's 60,000 hours on the tractor before the filter needs to be replaced/rebuilt.
It's 60,000 unless the parts break down unexpectedly, and that has happened to a lot of people. It could be less than 1. You could start your tractor tomorrow and find out you have an expensive, time-wasting problem.
It's not a simple issue. The manufacturer's rosy predictions about part longevity don't make emissions systems okay.
1. These parts force you to run the tractor at high RPM's, which is bad in every way, or you have to do frequent regenerations (also at high RPM's), which is also bad.
2. They make the tractors harder to work on, and that means tremendous aggravation and, if you pay a mechanic, money. Pre-emissions tractors are already hard enough to repair. Also, let's be blunt: many mechanics are not smart. There are a lot of guys out there who do trial-and-error all day; mostly error. You don't want to give your mechanic a hard puzzle if you don't have to.
3. Emissions parts often break down early, and they are expensive to fix.
4. The parts are going to continue to skyrocket in price, outpacing inflation by a country mile, and they will start disappearing when manufacturers decide it's time to push us to buy new tractors. Fancy electronic parts always seem to disappear from the market before ordinary parts, and they can't be repaired like ordinary parts.
My mower was released in around 2009. I have seen people talking about buying controllers in the old days for $80. They are now $340 on a good day. That is approximately three times the rate of inflation.
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
2016 FREIGHTLINER  CASCADIA TADC (A59575)
2016 FREIGHTLINER...
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A56436)
2023 Kubota U48-5...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2012 DOOSAN G25KW GENERATOR (A58214)
2012 DOOSAN G25KW...
