Backhoe update. I'm making progress (Video included)
/ Backhoe update. I'm making progress (Video included) #101
I still have a lot finish work left to do, grinding, paint, rear axle, hydraulic lines re-routing, seat post and seat, but you get the idea. The frame started out as a home made motorcycle lift I made a few years ago, which started out as a old mobile home trailer frame, I just recycled the metal, plus bought some new. I am still learning. Everytime I startit up I realize a new improvement that is needed. Give me time and it should/will work fine. Glad my project inspired someone.
/ Backhoe update. I'm making progress (Video included) #102
The best thing about my rig is I can pull a few pins and put it back on a kubota tractor with out any problems. Got a feeling it will stay on the towable frame for a while,at least until I get all my digging projects finished, and Dad's, and my neighbors.
/ Backhoe update. I'm making progress (Video included) #103
I can't wait to say, "I can dig it."
Oh yeah, daddy-o!
Ok, this is my first try at adding the pics, so if they do not show go easy on me.
Great idea on a towable version of that backhoe.
I came across a site Ground Hawg Towable Backhoe and am gonna use his photos as a guide for mine. But I'm not gonna buy the plans as I'm gonna use the same boom and cylinders for my backhoe and the bucket I made.
So I'm gonna go with his pictures and just build the frame stronger to hold the extra weight of my boom and stick, and the heavier cylinders.
I think the cylinders I got are at least 35 lbs a piece and the steel tubing is 25 lbs each.
I'm just guessing here. But I think the boom, stick, cylinders and bucket together weigh at least 250 lbs could be more, could be less.
All I know is that stuff is heavy and makes my back hurt. :laughing:
I'm also thinking of using a good engine I have laying around and the current pump mount. "To save money" And mount it for direct drive like in this photo.
I do have an old briggs single cylinder that just needs some carb work. I only gave $1.00 for the engine at a yard sale. The guy had it in the corner of his garage. I asked him about the engine. He said he could never get it to run. So he just bought a new engine for his riding mower and put that one in the corner.
I asked him how much he'd take for it. He said how about a $1.00 ? I said sure and whipped out a dollar bill. And then loaded it in my truck. Got it home and noticed no compression. Pulled the head off and noticed intake valve was stuck. I pulled it out and lubed it stuck it back in put the head back on.
Put gas in and it fired right off. It's a great engine. I just let it sit with some old gasoline in the carb. So now I need to get a carb kit for it.
Chad
/ Backhoe update. I'm making progress (Video included) #105
I am a firm believer in not re-inventing the wheel. Use what others have designed and try and make their design better. Recycling metal is a must for us back yard fabricators, so I used what I had available at the time. Waste not want not. The finished product may not be as pretty as a new laid out cad plan digger or a professional one, but it will still be functional and mine. Best of luck on your build. Credits: J.J. on this forum gave me some good advice on hydraulic componets. He is a pretty sharp when it comes to this stuff.
/ Backhoe update. I'm making progress (Video included) #106
Chad
Good on you, Chad!:thumbsup: Great deal on an engine for One dollar!:cool:;) As for the gummed up carb, try cleaning it first. Leaving gasoline in the tank during hot months without running an engine typically evaporates and leaves residues behind. If the carb needed a kit anyway, then go ahead. Otherwise cleaning will get 'er done.:D
/ Backhoe update. I'm making progress (Video included) #107
Like to see it as you do the build.
/ Backhoe update. I'm making progress (Video included) #108
Ok folks, I got most of the welding finished on my towable hoe, also finished the hydraulics and they work great. Slapped a seat on it and tried it out. I thought it would be handicapped because of digging force, man was I wrong. The stabilizer jacks do their job, this thing rocks.
/ Backhoe update. I'm making progress (Video included) #109
Congratulations!:thumbsup: Always good to see the successful completion of a project. And yes, I am envious. One question about stability as you dig: do you keep the towing tractor hooked up for additional anchoring? How prone to lifting off the ground are the castor wheels when the digger is not hooked up to the towing tractor? The reason I'm asking is because when I position my outriggers I suspect I'll have to angle them towards the work area as much as I can in order to benefit the most from the limited amount of weight I'll have to counterbalance the force of my digging.
/ Backhoe update. I'm making progress (Video included) #110
Chad
BIG MISTAKE ! You have to remake your boom and stick. Match Peavey's Kubota , those engineers have already done the math and it works . I bet you his boom and stick are made out of 1/8" thick stock and the cylinder mounts/gussets are 1/4" plate . You will spend needless time and money trying to make everything else strong enough to take the stresses of such a long boom & stick. Remember this " A 1/2" thick angle iron snapped right in half like a twig ", that should alert you to the stresses involved. There are no advantages to keeping it that long if it doesn't work and you have already proven that many times over.
/ Backhoe update. I'm making progress (Video included) #111
...those engineers have already done the math and it works .
More than that, I bet they paid attention to a lot of trial and error and copied what worked out. Someone designed it, built it, and broke it, and then redesigned it and broke it a few times more. I will bet that's where the finished "math" came from. Remember, while it was engineers who wrote the tables and books, it was an engineer who wrote Murphy's Laws.
/ Backhoe update. I'm making progress (Video included) #112
When I keep the tractor hooked up to the back hoe the rear wheels are approximately 6 to 8 inches off the ground, they never actually touch the ground until I disconnect from the tractor. When disconnected from the tractor the wheels simply act as any trailer axle, allowing a 4 pt. connection to the ground, however you have to keep the stabilizers close to the ground when operating separate from the tractor or the rear wheels will leave the ground. I have'nt actually dug with it much disconnected from the tractor, but I have moved it around the yard some when disconnected, to see how hard it would be to articulate by it self.
Positioning the stabilizers forward will be a plus, especially when not connected to a tractor or pick up truck, it would allow better digging force this way. Mine kubota hoe stabilizers are just slightly forward, however when they are in the downward position, they take all the stress from the hoe, thats they way it was designed to prevent damage to the tractor frame.
/ Backhoe update. I'm making progress (Video included) #113
Works something like this. Disconnected from the tractor, stabilzers up the caster wheel s go up. Stabilizers down, caster wheels go down. Raise stabilizers up to where the main axle is helping support the weight of the hoe, straighten out boom against the ground and operate the jacks to lift the stabilizers and main axle off the ground (all weight on boom and sqaure tubing frame) then simply use the boom to move the frame forward, backward, side to side. I must say the it is a lot easier to just use the tractor to position the hoe where needed, but there is a definite advantage to operating separate from a tractor like tight places, and such. Keep in mind the hydraulic cylinders will exert more force than a weak frame can support. Longer is not always better. REMEMBER IT'S NOT ALWAYS THE SIZE OF THE SHIP THATS IMPORTANT. Hope I was able to answer your questions. Let me know how it works out for you.
/ Backhoe update. I'm making progress (Video included) #114
Yep those parts are expensive. I wouldn't continue building this one. But I've already got $1,000.00 in hydraulics and steel. So I figured heck I might as well put another $1,000.00 into it.The fittings alone just to connect the hoses to the valve are $70.00
But if I hadn't already put the $1,000.00 into it. I would be just buying one of the pre made towable backhoes.
Chad
or you quickly see how finding a used $3000 factory built hoe which will out perform the towables and anything you can build at home is a no brainier.
/ Backhoe update. I'm making progress (Video included) #115
Sure, do it the easy way. All joking aside, I would not have attempted to build this thing if I did not really enjoy welding and fabricating. I guess it is up to the preference of the individual that needs/wants one. If you enjoy building things, then go for it, you will learn more, and be able to take pride in a build well done. If you want to purchase a hoe, go for it. Although I believe I have taken a back hoe attachment and built a strong suitable frame to make it more versitile, there is no doubt that a traditional factory back hoe will accomplish more heavy work when compared to mine, but unless I plan on digging deeper than 8 feet or using it as a crane, I think my little hoe will serve my needs just fine.
/ Backhoe update. I'm making progress (Video included) #116
peavey:
That is what I see as being an important consideration as I build mine. I'm building a backhoe onto the rear of a garden tractor. I do not have an FEL on it nor will I be putting one on. Instead, I have a dozer blade from another garden tractor that I will attach and convert to hydraulic control. If I need more weight to counter the weight and forces from the backhoe, I plan to hang them on that blade. That blade will also serve as the third point when anchoring my machine while digging. I have a thread going which describes what I'm doing which you may or may not have seen. It's
http://www.tractorbynet.com/forums/build-yourself/209127-its-time-either-get-started.html.
/ Backhoe update. I'm making progress (Video included) #117
Converting a dozer blade to hydraulic control is a great idea, I'm assuming the dozer blade will be fitted on the front of the machine. It should provide enough down pressure to lift the tractor wheels off the ground. That should do the trick for counter balance weight/force. Remember, you do not have to add enough counter weight to compensate for the digging force of the back hoe, just an opposite force of down pressure from the dozer blade when digging. Additional frame supports to keep the tractor frame from snapping into is a must. Axles weight bearing ability must be considered also.
/ Backhoe update. I'm making progress (Video included) #118
My plan is to just get the weight off the front wheels as I set up to dig. Only add weights if necessary and just have those as hang-ons to slip over the top of the blade. I have done some reinforcing of the frame and may have to improve on that if it is needed. As for the rear axle, it appears to be of cast iron construction and I'm guessing it will be able to carry the load. That leaves the question of how far to extend the outriggers and whether to sweep them further back than yours are. At this point I still have options.:)
Your right. It's a big mistake. I don't know what I was thinking wanting to use the current boom and stick again. I just know it'll break something again.
My boom and stick material is 1/8" thick. I decided that I will go ahead and buy the plans when I get the money and get the material and cylinders listed in them. This way I know I'll get the thing done right.
I'll just use my current cylinders for something else.
Chad
/ Backhoe update. I'm making progress (Video included) #120
The closer you can position the stabilizers to the back hoe the better for support of the back hoe when operating it, but the more weight the tractor will have to support when not using the back hoe. A few inches either way will make a big difference. Think of a wooden ruler balanced in the middle of something at the 6" mark. add 4oz. of weight to the 3" mark and it will take less than 4 oz of weight on the 12" mark to counter balance. The axle will have to support the weight of the hoe, the farther it extends from the frame of the tractor the more stress will be placed on it. Keep all the weight as close to the tractor as possible.
