Backhoe Backhoe Pictorial Tutorial - Removing BH90
/ Backhoe Pictorial Tutorial - Removing BH90 #21
txdon,
is that hydraulic tnt setup factory or ???
Barnee, Check out the post that I just replied to, about the tnt, on jmc's post: /forums/images/graemlins/wink.gif
Kubota Buying/Pricing forum
Kubota Top and Tilt
05/16/04 10:38 PM
/ Backhoe Pictorial Tutorial - Removing BH90 #23
Don,
Thanks for taking the time to post the pictures. You have the setup I want with the TnT and BH90 and it really helps to see actual pictures of the installation.
Thanks again
Leroy
/ Backhoe Pictorial Tutorial - Removing BH90 #24
</font><font color="blue" class="small">( Leroy, The BH frame does not interfere with the 3 point hitch or T&T. See attached photo. )</font>
So I wonder why my dealer told me, and the manual reads, that the 3 point has to be removed, lift arms and leveling arms, for installation of the BH90. I couldn't leave well enough alone and hooked up the BH90 today, without removing the lift arms or anything. I only loosened the stablizers so the arms could float free until I had the BH90 connected.
The only thing I see that could be an issue is the possibility of a stabilizer hose hooking on the end of the lift arms, but that's easy to watch and avoid.
I do believe this is why they cut the frames on the sub-frame and the BH they way they did.
Anyone have any tips on the lift arms when using the BH90 on the back?
Thanks,
Chris
/ Backhoe Pictorial Tutorial - Removing BH90 #25
</font><font color="blue" class="small">( .............. When storing backhoe, install the dust caps onto the backhoe's hydraulic nipples to prevent contamination.
The end. /forums/images/graemlins/wink.gif )</font>
Don..... great picture essay of how to remove the hoe. It seems that it is as simple as the BX hoe to remove. The only thing that I do differently is that when I remove the hoe, I put the two ends of the hydro lines together rather than using the caps. I find that there is no contamination using this method and there is no chance of rust on the male side of the connector either. Also, should there be any expansion of hydro fluid by temperature change, this will allow the fluid to circulate within the system and balance out while the hoe is at rest.
/ Backhoe Pictorial Tutorial - Removing BH90 #26
txdon:
Thanks for the post/pics. Well done. I knew the BH removal was easier on the KUB than the NH I bot. You've just shown it! The NH is much more of a hassle as the subframe comes off with the BH, the arms/bucket are stored stretched out. Anyway, thanks.
JEH
/ Backhoe Pictorial Tutorial - Removing BH90 #27
Also thanks so much from me! You've made the process so clear, I can actually see how the process would be reversed to reattach the backhoe!
/ Backhoe Pictorial Tutorial - Removing BH90 #28
You really should be doing the manuals for Kubota. This is much better than the book. And I learned a few things, even after a year with the BH-90!
/ Backhoe Pictorial Tutorial - Removing BH90 #29
</font><font color="blue" class="small">( txdon:
JEH )</font>
Thanks for the plug for <font color="orange"> ORANGE </font>
/ Backhoe Pictorial Tutorial - Removing BH90 #30
I know this post is old, but it should be a sticky to help out us newbie hoe owners.;)
Great job TXDon!
/ Backhoe Pictorial Tutorial - Removing BH90 #31
You're right Swampvol! I plan to get a BH and have wondered about the process. I bookmarked this thread. Thanks TXdon!
/ Backhoe Pictorial Tutorial - Removing BH90 #32
txdon said:
11. Disconnect hydraulic hoses on the following manner: (1.) Disconnect the inlet and outlet from the tractor. (2.) Connect tractor's outlet hose to the coupler of return hose.
One thing TXDon forgot to mention...make sure the tractor is turned off before disconnecting the hoses!!!
/ Backhoe Pictorial Tutorial - Removing BH90 #33
TXDon made that point very clear in step 9
I was thinking I might need a picture of my hand on the key on step nine to be consistent or someone might miss it.;)
I take the hoe off and on about every 6 months and still have to go step by step from the manual. The BH has been preforming flawlessly, except that one time it hit the water line.:rolleyes:
/ Backhoe Pictorial Tutorial - Removing BH90 #35
I find that get the backhoe off is much easier that putting it back on. When I raise it up with the stabilizers, it wants to move to one side or the other. One stabilizer stays put and the other slides in as I am raising the hoe. The thing that ticks me off, is it is never consistent.
/ Backhoe Pictorial Tutorial - Removing BH90 #36
Doh! That he did.
Ill be taking mine off next weekend for the first time with my laptop and this thread.:D
Again, great thread TXDon!
/ Backhoe Pictorial Tutorial - Removing BH90 #37
I use "cribbing" to keep the hoe in the raised position. When I need to reinstall the hoe,I need only to back into it and start the installation process :confused:
/ Backhoe Pictorial Tutorial - Removing BH90 #38
I thought about just sliding a floor jack under it when I go to put it back on. I'll try that next time.
/ Backhoe Pictorial Tutorial - Removing BH90 #39
Good tutorial. Same procedure for B26 backhoe. The only aspect I have some trouble with is getting the pins out. Finding the "sweet" spot that releases the pins has been a challenge for me. As you say, raising the rear wheels doesn't work.
2011 Black Troxell T120 Vacuum/Water Hauler (A64194)
2011 Black Troxell...
King Kutter II Tiller for sale.
King Kutter II...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2019 Ford F-150...
Club Car Emergency Cart (A64557)
Club Car Emergency...
2007 Chevrolet Silverado 3500 4x4 Service Truck (A64556)
2007 Chevrolet...
