Backhoe control configuration
/ Backhoe control configuration #1
brettski
Chicago IL
Foton 404
Picked up a (Chinese mfgd) 3-point backhoe. Time to practice, but I have a concern for the controls configuration. The dipper direction (control direction vs the actual dipper movement) seems to be unintuitive. It is laid out as follows:
At the right, the dipper moves out when the control is pulled toward the operator. In my mind, the dipper should draw back when the control is drawn back.
The change is simple, so I can flip-flop the hoses either way. I just don't want to spend time learning and getting used to the wrong configuration. What say you, backhoe owners and operators?
/ Backhoe control configuration #2
It's backwards to everything I have used. I wou flip the hoses.
/ Backhoe control configuration #4
Boom looks right, dipper is backwards
/ Backhoe control configuration #5
Everything is correct except the stick , or dipper .
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
2001 INT 4900 DT 530 (A62679)
2001 INT 4900 DT...
AGT Top Cat Brush Cutter (A64047)
AGT Top Cat Brush...
NEW Wolverine GB-11-72W Skid Steer Grapple Bucket (A62679)
NEW Wolverine...
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
2021 Peterbilt 579 (A64127)
2021 Peterbilt 579...
