Backhoe control configuration
/ Backhoe control configuration #1
brettski
Chicago IL
Foton 404
Picked up a (Chinese mfgd) 3-point backhoe. Time to practice, but I have a concern for the controls configuration. The dipper direction (control direction vs the actual dipper movement) seems to be unintuitive. It is laid out as follows:
At the right, the dipper moves out when the control is pulled toward the operator. In my mind, the dipper should draw back when the control is drawn back.
The change is simple, so I can flip-flop the hoses either way. I just don't want to spend time learning and getting used to the wrong configuration. What say you, backhoe owners and operators?
/ Backhoe control configuration #2
It's backwards to everything I have used. I wou flip the hoses.
/ Backhoe control configuration #4
Boom looks right, dipper is backwards
/ Backhoe control configuration #5
Everything is correct except the stick , or dipper .
KUBOTA KX71-3 EXCAVATOR (A65053)
KUBOTA KX71-3...
New/Unused Quick Attach Open Back Mounting Plate (A65583)
New/Unused Quick...
Freightliner Columbia (A63689)
Freightliner...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
2015 Kubota RTVX1100C (A62177)
2015 Kubota...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
