3-Point Hitch B7800 Extendable 3-point link arms
/ B7800 Extendable 3-point link arms #1
Lunger
NY Dutchess county
B7800
I thought I read this here before and tryed to do a search for ir but came up empty, what I am looking for are part #'s and to make sure they will fit from the 2910... the ones on my B7800 are shot (turn Buckles Threaded Rod) thanks
thanks for the link but the part #'s dont seem to be valid...
/ B7800 Extendable 3-point link arms #4
Current part numbers
6C07065333 STABILIZER $16.35 X2 $32.70
6C07065320 PIPE $14.31 X2 $28.62
6C07065350 BOLT $3:37 X2 $6.74
6C07065310 BRACKET $29.68 X2 $59.36
0512251235 PIN $2.31 X2 $4.62
0512251237 PIN $2.31 X2 $4.62
TOTAL $136.66
Here's what I used on my B7500. The second smartest thing I've done...the smartest was buying the tractor.
/ B7800 Extendable 3-point link arms #5
Lunger
Finally got time to check on the numbers.
The numbers are correct. Tractorsmart leaves out the last -.
6C170-65424 $114.05 Lower Link LH
6C170-65510 $130.14 Lower Link LH
6C170-65524 $114.05 Lower Link RH
6C170-65510 $130.14 Lower Link RH
6C170-65430 $26.03 Lever 2 pcs
6C170-65440 $2.61 Spring 2 pcs
6C170-65450 $3.92 Pin 2 pcs
05122-50640 $0.58 Pin, Joint 2 pcs
05511-51615 $0.15 Pin, Split 2 pcs
05511-50530 $0.15 Pin, Split 2 pcs
Total 555.20 plus shipping (from Tractorsmart)`
/ B7800 Extendable 3-point link arms #6
Lunger,
You said extendable link arms, but did you mean the Telescopic Stabilizers?
Thebowman gave you prices for the stabilizers, and Ronjhall gave you info on the extendable links, from what I can see.
You can see that the conversion to the complete B2910 set up is very expensive, because you would need to order both sets of parts.
Although you said extendable link arms in you post, when you said the turn buckles on your 7800 were shot, I thought you were really wanting the stabilizers.
Which are you looking for? Pretty expensive for the whole setup, isn't it?
The cost of the parts sure shocked me when I was wondering if I could adapt the longer extendable arms to my BX. Yes I know doing so would reduce the lift capacity of my bx's 3PH, but I really wold like to use my Rhino HPHD PHD on the BX and that looks impossible without longer lower arms... /forums/images/graemlins/frown.gif
/ B7800 Extendable 3-point link arms #7
<font color="blue"> I really wold like to use my Rhino HPHD PHD on the BX </font>
Bill,
You have really been getting into this welding and modification thing lately, why don't you fab and weld a new plate systejm on the yoke of the PHD that will work for both tractors?
BTW, good job on the projects that you have done.
/ B7800 Extendable 3-point link arms #8
That's a great idea, Jerry.
I better think about which hat I normally wear! Seem to think more in terms of wood and sawdust than metal and sparks!
I'm going to do that...or try to anyway... /forums/images/graemlins/cool.gif /forums/images/graemlins/smile.gif
/ B7800 Extendable 3-point link arms #9
Bill
I gave a link to the B2910 Arms thinking that is what Lunger wanted. Well whichever parts he wants the numbers are here. /forums/images/graemlins/cool.gif
/ B7800 Extendable 3-point link arms #10
theboman,
Thanks for the part number list, I'm going to do my BX2200, and from what I've read in the various posts, the BX can use the same parts. I have a question on part number 6C07065310 BRACKET, where does this fit in? By any chance, do you have a picture of your installation?
/ B7800 Extendable 3-point link arms #11
I didn't take pics sorry.
The brackets.... Going from memory. It the parts that goes onto the back of the tractor where the arms attach. If that makes any sense.
Under the drawbar the rod that goes from one side of the tractor where the stablizers attach.....
thanks for all the info... what I am looking for is the adjustable stabilizers not the whole arm's
/ B7800 Extendable 3-point link arms #13
check with dealer they should be able to get them as a complete unit a lot cheaper. i was quoted about 200 for a l3410gst i was looking at.
/ B7800 Extendable 3-point link arms #15
</font><font color="blue" class="small">( theboman,
Thanks for the part number list, I'm going to do my BX2200, and from what I've read in the various posts, the BX can use the same parts. I have a question on part number 6C07065310 BRACKET, where does this fit in? By any chance, do you have a picture of your installation? )</font>
Check out the picture. The BRACKET is either the part on the sway bar where the the shaft attaches or the part next to the draw bar where the shaft attaches and I think it's this part.
http://www.tractorbynet.com/forumfiles/5-154404-P5290016.JPG
2022 EZ-GO ELITE...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
New/Unused ATS Cement Mixer (A65583)
New/Unused ATS...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
Lincoln Electric Shield-Arc SAE-400 - Radiator Missing - For Parts or Rebuild (A63689)
Lincoln Electric...
2018 TAKEUCHI TL8 SKID STEER (A59914)
2018 TAKEUCHI TL8...
