B7800/B29xx Telescoping stabilizers
   / B7800/B29xx Telescoping stabilizers #11
I'd love to help you but I upgraded my B7800.
   / B7800/B29xx Telescoping stabilizers #12
Medic,
Thanks for the reply. If you can collapse the stabilizer to the minimum and measure length, and then extend and measure the length that would help.
I believe that these will also work on my L2350 DT.
Thanks again.
   / B7800/B29xx Telescoping stabilizers #13
No I meant I'd love to help but I upgraded by B7800 to an L3940 . I no longer have it sorry.
   / B7800/B29xx Telescoping stabilizers #14
I did this upgrade on my 2620 and it's great. There is no side to side play. The holes are not all evenly spaced which gives you all the range of adjustment you could want.
   / B7800/B29xx Telescoping stabilizers #15
Medic,
ETW,
Thanks for the reply as well. Would you be able to measure the range? compressed and extended?
Do you have a pic handy?
Thanks again.
   / B7800/B29xx Telescoping stabilizers #16
So Evil, was it an easy upgrade? Would you recommend/encourage others to do it to improve their quality of life on the tractor? Thanks in advance! :p
Troy
   / B7800/B29xx Telescoping stabilizers #17
Troy
I would recommend it, although it cost me about $170 to 'fix' what some may consider a minor issue. Adjusting the check chains was a pain in the neck. Paint on the threads, trying to figure out which way to rotate the turnbuckle, etc. I like how the arms stay put now even when there is nothing connected to the 3 pt. It would be a nice standard feature, but I understand the economy vs deluxe model tradeoffs. It was very easy to make the swap and the process and parts list is well documented on these forums.
   / B7800/B29xx Telescoping stabilizers #18
Well then, I'll be calling my dealer and ordering the parts. If all it does is eliminate the confusion of which way to turn the turnbuckle that is reason enough for me. I bought my tractor to enjoy, not to be frustrated by silly fixable things :p
Troy
   / B7800/B29xx Telescoping stabilizers #19
You could get Pat's easy change system or any number of other products that simplify 3 pt hookups instead. I believe Landpride makes something for this purpose also.
   / B7800/B29xx Telescoping stabilizers #20
I have the LandPride Quick Hitch thingy. But as you know, some things should have no sway and some should have a little. The telescoping links would make swapping back and forth a breeze with no confusion. As I get older I seem to confuse more easily so I try to do what I can to complicate how easily I confuse :confused:
Troy
2018 John Deere 2025R Tractor - 647 Hours (A56435)
2018 John Deere...
2012 Dodge Grand Caravan (A56859)
2012 Dodge Grand...
2022 Club Car Tempo Cart (A55852)
2022 Club Car...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
Skid Steer Heavy Duty Auger Drive w/ 3 Bits (New/Unused) (A59225)
Skid Steer Heavy...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
