B7800/B29xx Telescoping stabilizers
   / B7800/B29xx Telescoping stabilizers #41
Can you post a link?
Tried searching ebay but without any luck finding those. They look good. Wonder if I could adapt a set to my BX?
I would not want to be without them on my B2910...
Bill
   / B7800/B29xx Telescoping stabilizers #42
eBay search “stabilizer bar tractor”. Note different ends for different tractors. Also can buy pieces to make your own. It was pretty easy to make fit for the M59. Had to cut and weld a tab for the B26
   / B7800/B29xx Telescoping stabilizers #43
Thanks but that search turns up about what I looked at before.
Do you have an item number or seller's name?
I figured you bought what is shown in the picture as one item. Did you buy several items and fit them together yourself. I understand you mentioned you needed to make a mod to fit them to the Kubota. That should be no problem for me...
Thanks for any further info you can supply.
   / B7800/B29xx Telescoping stabilizers #45
That is one of several on eBay. Internet search of telescoping tractor bar with give other options. I believe Weavers tractor supply where I got the leveling box carried them too.
   / B7800/B29xx Telescoping stabilizers #46
Thanks!
I saw that one but it did not register. I guess it should have since it is blue...:laughing:
Appreciate you taking the time to post that link!
Bill
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A56858)
2012 Mack CXU613...
LOT: Receiver Hitches, 1/2 Ton Sheet Clamp, Pipe Threader (A59076)
LOT: Receiver...
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
32" X 144" X 48" METAL STORAGE RACK (A58374)
32" X 144" X 48"...
2017 Peterbilt 348 Hood 7000 Grapple Truck (A55973)
2017 Peterbilt 348...
2016 Ram 3500 Crew Cab Chipper Truck (A55973)
2016 Ram 3500 Crew...
