B7800/B29xx Telescoping stabilizers
/ B7800/B29xx Telescoping stabilizers #1
N1ST
Enfield, CT
Kubota B7800
I'm considering replacing my B7800 turnbuckles with the telescoping stabilizer ala B29xx. $145 for parts at TractorSmart.com. Someone that has done this or has the B29xx stock stabilizers - please comment on if there is any side-to-side play in them. Something that I like abouit the turnbuckles is that you can adjust them to have no play. Things I don't like is that they don't stay separated and can bind at the bracket when lifting the arms.
/ B7800/B29xx Telescoping stabilizers #2
I converted from turnbuckle style stabilizers to telescoping on my B7610 w/ parts from B2910. Although some have posted and claim to actually like the turnbuckles better, in my opinion, I'd do it again a thousand times over. Makes changing implements a whole lot easier. I have zero issues with side to side play.
/ B7800/B29xx Telescoping stabilizers #3
I strongly second the opinion on the telescoping stabilizers being the best improvement in my B7800 that I have ever made. Implement changes are MUCH faster and easier on the back than when I had the turnbuckles. The change only took about an hour, with interruptions. I get minimal sway with these. I could probably get less if I was more exacting when attaching implements. It's the best $130 I have ever spent on the tractor!
/ B7800/B29xx Telescoping stabilizers #4
+1 :)
Thanks for your opinions guys, and the nice picture.
/ B7800/B29xx Telescoping stabilizers #6
$130?? I thought you needed to by the whole B2910 3-point hitch assembly and the cost was like $700.
What are the part numbers you need for the minimal turnbuckle to Telescoping arm change? I am very interested. Thanks
The parts cost $144.40
02174-50160 2 NUT, M16 0.71 $1.42
04011-50120 4 WASHER, PLAIN 0.13 $0.52
04015-60160 2 WASHER, PLAIN 0.32 $0.64
04512-60160 2 WASHER, SPRING 0.19 $0.38
05122-51235 2 PIN, JOINT 1.49 $2.98
05122-61245 2 PIN, JOINT 1.23 $2.46
05511-50425 4 PIN, SPLIT 0.13 $0.52
05515-61000 2 PIN, SNAP 0.45 $0.90
6C070-65310 2 BRACKET,STABILIZER 30.69 $61.38
6C070-65320 2 PIPE, STABILIZER 15.7 $31.40
6C070-65333 2 PLATE, STABILIZER 15.7 $31.40
6C070-65340 2 PIN,STABILIZER 2.6 $5.20
6C070-65350 2 BOLT, STABILIZER 2.6 $5.20
TractorSmart.com is your online source for Kubota online parts.
Phone 717-450-1250
/ B7800/B29xx Telescoping stabilizers #8
I was thinking of doing this to only ONE side and keeping the turnbuckle on the other side... anyone tried this? :confused:
/ B7800/B29xx Telescoping stabilizers #9
Can someone clarify in the picture above that's the improved setup? I bought my 7800 used and apparently it's been upgraded.
/ B7800/B29xx Telescoping stabilizers #10
I'm interested in converting my L2350 to telescoping stabilizers and it looks like I could possibly make these work. Would you be able to give me the dimensions of the stabilizer--fully retracted and fully extended?
Thanks.
/ B7800/B29xx Telescoping stabilizers #12
Medic,
Thanks for the reply. If you can collapse the stabilizer to the minimum and measure length, and then extend and measure the length that would help.
I believe that these will also work on my L2350 DT.
Thanks again.
/ B7800/B29xx Telescoping stabilizers #13
No I meant I'd love to help but I upgraded by B7800 to an L3940 . I no longer have it sorry.
/ B7800/B29xx Telescoping stabilizers #14
I did this upgrade on my 2620 and it's great. There is no side to side play. The holes are not all evenly spaced which gives you all the range of adjustment you could want.
/ B7800/B29xx Telescoping stabilizers #15
Medic,
ETW,
Thanks for the reply as well. Would you be able to measure the range? compressed and extended?
Do you have a pic handy?
Thanks again.
/ B7800/B29xx Telescoping stabilizers #16
So Evil, was it an easy upgrade? Would you recommend/encourage others to do it to improve their quality of life on the tractor? Thanks in advance! :p
Troy
/ B7800/B29xx Telescoping stabilizers #17
Troy
I would recommend it, although it cost me about $170 to 'fix' what some may consider a minor issue. Adjusting the check chains was a pain in the neck. Paint on the threads, trying to figure out which way to rotate the turnbuckle, etc. I like how the arms stay put now even when there is nothing connected to the 3 pt. It would be a nice standard feature, but I understand the economy vs deluxe model tradeoffs. It was very easy to make the swap and the process and parts list is well documented on these forums.
/ B7800/B29xx Telescoping stabilizers #18
Well then, I'll be calling my dealer and ordering the parts. If all it does is eliminate the confusion of which way to turn the turnbuckle that is reason enough for me. I bought my tractor to enjoy, not to be frustrated by silly fixable things :p
Troy
/ B7800/B29xx Telescoping stabilizers #19
You could get Pat's easy change system or any number of other products that simplify 3 pt hookups instead. I believe Landpride makes something for this purpose also.
/ B7800/B29xx Telescoping stabilizers #20
I have the LandPride Quick Hitch thingy. But as you know, some things should have no sway and some should have a little. The telescoping links would make swapping back and forth a breeze with no confusion. As I get older I seem to confuse more easily so I try to do what I can to complicate how easily I confuse :confused:
Troy
Unused 2023 Norden SQ90 Hydraulic Bale Squeeze Tractor Attachment (A66734)
Unused 2023 Norden...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2011 FORD F-550 SUPER DUTY (A67714)
2011 FORD F-550...
Unused 2023 Monroe-Tufline DS1120T 10ft. Hydraulic Box Scraper Tractor Attachment (A66734)
Unused 2023...
2007 Cadillac Escalade SUV (A66738)
2007 Cadillac...
WARREN POWER SYSTEM LIGHT PLANT (INOPERABLE) (A68842)
WARREN POWER...
