b7100hst starting?
/ b7100hst starting? #1
bruski
rural Missouri
Kubota b2400HSD
I've had a later model B7100HST for about 6 months. Been very happy with its operation and ease of servicing. I have a question about starting. It sometimes (after warming the glow plug) does nothing when I turn the ignition the first time or two, sort of clicks, then starts right up. Is this the battery going? The starter going? Sort of reminds me of when I was a kid and we'd say about a starter, "It has a dead spot." The problem is intermittent. Should I ignore it until something fails?
Bruski
/ b7100hst starting? #2
If it finally turns over fine once it "catches" then I would say that the battery is fine. Possibly either the ignition switch going bad or the starter having that "dead spot" in it.
/ b7100hst starting? #3
Make sure you clean the battery terminals well before doing anything else. One of the reasons I got my B6100 so cheap is because it would only start with a jump. I cleaned the terminals and haven't had an issue since and it still has the same battery.
/ b7100hst starting? #4
it also could be the switch on clutch pedal
i have the same problem once and a while
Yep, I believe this is it. Thanks!
Bruski
/ b7100hst starting? #6
My batt terminals were extremely corroded on the B7100 I bought this summer. Cleaned them up real good and put dielectric grease on the terminals and now no starting problems.
New/Unused CFG Industrial H15R Mini Excavator (A65579)
New/Unused CFG...
BUCK STOVE FIREPLACE INSERT (A64276)
BUCK STOVE...
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A64280)
(INOP)1989 NISSAN...
2018 CASE 750M WT CRAWLER DOZER (A65056)
2018 CASE 750M WT...
2019 CATERPILLAR 305E2 CR EXCAVATOR (A65056)
2019 CATERPILLAR...
2022 TAKEUCHI TL12V2 SKID STEER (A65053)
2022 TAKEUCHI...
