b7100hst starting?
/ b7100hst starting? #1
bruski
rural Missouri
Kubota b2400HSD
I've had a later model B7100HST for about 6 months. Been very happy with its operation and ease of servicing. I have a question about starting. It sometimes (after warming the glow plug) does nothing when I turn the ignition the first time or two, sort of clicks, then starts right up. Is this the battery going? The starter going? Sort of reminds me of when I was a kid and we'd say about a starter, "It has a dead spot." The problem is intermittent. Should I ignore it until something fails?
Bruski
/ b7100hst starting? #2
If it finally turns over fine once it "catches" then I would say that the battery is fine. Possibly either the ignition switch going bad or the starter having that "dead spot" in it.
/ b7100hst starting? #3
Make sure you clean the battery terminals well before doing anything else. One of the reasons I got my B6100 so cheap is because it would only start with a jump. I cleaned the terminals and haven't had an issue since and it still has the same battery.
/ b7100hst starting? #4
it also could be the switch on clutch pedal
i have the same problem once and a while
Yep, I believe this is it. Thanks!
Bruski
/ b7100hst starting? #6
My batt terminals were extremely corroded on the B7100 I bought this summer. Cleaned them up real good and put dielectric grease on the terminals and now no starting problems.
40' New Container (A62679)
40' New Container...
2015 CHEVROLET 2500 HD CREW CAB FLATBED TRUCK (A62130)
2015 CHEVROLET...
2016 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 KENWORTH T680...
2016 VOLVO DD25B DOUBLE DRUM ROLLER (A65053)
2016 VOLVO DD25B...
150 GALLON FUEL TANKS WITH BRACKETS (A65643)
150 GALLON FUEL...
2022 EZ-GO ELITE...
