b7100hst starting?
/ b7100hst starting? #1
bruski
Bronze Member
rural Missouri
Kubota b2400HSD
I've had a later model B7100HST for about 6 months. Been very happy with its operation and ease of servicing. I have a question about starting. It sometimes (after warming the glow plug) does nothing when I turn the ignition the first time or two, sort of clicks, then starts right up. Is this the battery going? The starter going? Sort of reminds me of when I was a kid and we'd say about a starter, "It has a dead spot." The problem is intermittent. Should I ignore it until something fails?
Bruski
/ b7100hst starting? #2
If it finally turns over fine once it "catches" then I would say that the battery is fine. Possibly either the ignition switch going bad or the starter having that "dead spot" in it.
/ b7100hst starting? #3
Make sure you clean the battery terminals well before doing anything else. One of the reasons I got my B6100 so cheap is because it would only start with a jump. I cleaned the terminals and haven't had an issue since and it still has the same battery.
/ b7100hst starting? #4
it also could be the switch on clutch pedal
i have the same problem once and a while
Yep, I believe this is it. Thanks!
Bruski
/ b7100hst starting? #6
My batt terminals were extremely corroded on the B7100 I bought this summer. Cleaned them up real good and put dielectric grease on the terminals and now no starting problems.
2012 KENWORTH T800 HYDROVAC (A67714)
2012 KENWORTH T800...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
2008 Sterling L7500 Series T/A Vactor 2115-J6 Combination Sewer Jetter Vacuum Truck (A66736)
2008 Sterling...
HELI 5K FORKLIFT (A67714)
HELI 5K FORKLIFT...
2006 W-W TRAILER 20' T/A ENCLOSED TRAILER (A67714)
2006 W-W TRAILER...
PORTA POTTY (A67714)
