B3030
/ B3030 #22
To be blaming the machine for the past operators abuse is just ....! Give your Kioti to the previous owner of the Kubota and then compare.
The 3030 is a 1800lb machine the was designed to do what a 1800lb machine will do. Getting stuck on wet grass is the fault of industrial tires that are frozen solid because the previous owner filled them with what ever, how is that Kubota's fault? Maybe you should take a breath, get real and re post.
/ B3030 #23
Don't blame the tractor for the previous owner's lack of care and whatever else they lacked.
/ B3030 #24
HMMMM Amish using a tractor? Sounds a bit fishy! Sounds like buyers remorse at best and a case of being mad at a dealer. Caveat emptor (or something like that) buyer beware
/ B3030 #25
Oh, the endless joys of Kubota products.....I sure miss my Kioti, shoulda never sold it.
I have a B3030. The 4x4 doesn't work. When shifting, I can feel the gears shift in to each other. So I'm assuming the problem is after the transmission. Maybe a busted driveshaft, broken gear etc in the front end? I looked at an assembly diagram for the 4x4 system. It's over my head, lot of parts in there. Anyone know these tractors well enough to point me in the right direction?
This tractor has been a POS since day one. Bought it used from some Amish guy.....NEVER trust the Amish. To add insult to injury, guy I bought it from filled the rear tires with WATER. That's all well and good in warm climates. Tires are frozen solid, literally. The thing has zero traction. I got it stuck in the grass today. Yes, stuck in the grass, not snow, not mud, but grass. Anyone wanna buy a piece of crap Kubota? Some key features: Underpowered, crappy hydro trans, weak *** loader, crappy 4x4, hard to start, slow, pathetic 3 point lift ability. Comfy seat though.
Painting all of the Amish with that broad brush slur says a lot about the man behind your words. Too bad about your tractor. Really.
/ B3030 #26
But it's pretty sad when I can literally get more done with a wheel barrow than I can with a 30 hp tractor
I know who will trade you a nice wheel barrow for that "piece of junk". It would make two people happy.
/ B3030 #27
I kind of hate to get involved in this, but flaming an entire brand based on bad experiences from one machine is not what I expect from someone who claims to know a lot about machinery. I am certainly no expert, but we have owned several tractors, Case, John Deere and Massey Ferguson that were nothing but trouble, trucks/cars Chevrolet, Dodge, Nissan etc., but accepted them for what they were and still consider all brands when buying new.
Check around on some old threads and you will find, "I'll never buy another Kubota, Kioti, John Deere etc."
Recently we've bought mostly Kubotas, but I'm far from "brand loyal" or whatever it's called as we own several different makes of tractors and my brother just bought a Kioti I would pick over the equivalent Kubota based on features and price. I believe all the top makes offer good products, if you get one that doesn't work for you, as mentioned, your best bet will be too fix it or get rid of it and move on.
/ B3030 #28
I believe the lift is around 870# and that doesn't include the weight of the bucket but check tractordata.com. Lift is around 2k on the 3 pt so you got hydraulic issues which could be the main culprit. I don't think a drain/refil is enough to get the wrong fluid completely out, think of all that bad fluid trapped in the pumps, cylinders, HST, etc. might try a flush. But still have to be open to the fact that perminant damage may have been done.
On the fwd. is the shaft spinning? Flip the bucket and lift the front tires off ground. Grab hold and spin, do u feel any resistance or grinding?
/ B3030 #29
Haven't seen this mentioned, but did you get a gauge and test where the relief valve pressure is set? Sounds like after 1,600 hours, the relief valve may be spongy. Get some shims and shim it back up to spec or a little higher if needed. My BX can easily lift 400 lbs on the 3PH, so something is wrong with your hydraulic pressure if you're having issues lifting a 7' rear blade. Don't know what spec is for pressure on a B3030 but I'm sure someone here will know - maybe around 2,300 or 2,500 PSI.
Sorry to say, but I don't think this is a Kubota issue so much as you getting a lemon used-tractor. Don't know how long ago you bought it, but with all those issues, I'd go back to the dealer to see if he can help you out. I assume there was no warranty, but it sounds like they didn't check it out too well when they took it in on trade. Good luck.
/ B3030 #30
Another thought (don't take this the wrong way) do you have the 4wd lever in the right position? Mine is down by my feet and that little icon that shows engagement isn't that easy to see the difference. I once thought i was putting it in 4wd just to find out that I looked at it wrong and was reversed.
Mine take a little work to guarantee positive engagement and have sometimes not had it "lock".
But check for shaft spin and spin those wheels by hand to confirm.
/ B3030 #31
I also have a B3030 and think you have a tractor that was badly abused then traded when things started going wrong. I have a rear counterweight that weighs about 900 lbs and the 3pt lifts that like it was a block of wood. The FEL will lift that same counterweight high enough to move it around but not enough to put it into the back of a pickup. 700lbs in the bucket should be easy enough. My tractor likes the glow plugs even when the weather is mild but will start at -20C (about 0 F for y'all) not plugged in. Maybe you have some glow plugs that have lost interest. No comment on the front wheel drive assembly beyond that it goes in easier if you are rolling so the gears match going in and you might have to reverse direction a couple of feet to take load off the gears to pull it out easily.
This is my third Kubota. I don't buy more of things I don't like.
/ B3030 #32
In regards to the hydraulics, as mentioned above, check operating pressure. I think the pressure relief valve is weak. Worst case would the the pump is weak, but check relief first.
In regards to the 4x4. If you can overhaul a pickup drive axle, you can overhaul the Kubota front end. There's no rocket science here. The Kubota front drive system is simply made up of a spider geared center section that is 1 to 1 drive ratio and two outer wheel assemblies that are composed of ring/pinion gear assemblies. No mystery at all.
Before I started tearing gear cases apart though I'd run some tests to see what's turning when 4x4 is engaged. Access the front driveshaft, jack up the front tires and start turning things by hand. Observe what's happening and the differences of it being engaged in 4x4 and 2x4. You'll narrow down the problem real quick by doing that.
It's an assumption on our parts that you are mechanical and know how to diagnose equipment based on your self description of your experiences with various machines.
If our assumption is wrong, just say that. If our assumption is accurate, then display that knowledge and after properly analyzing everything if you are still stumped, report back with your procedures and findings. There are people in this conversation that can help you brainstorm thru this problem.
Brand bashing has so far resulted in 32 posts and no answers. We are all interested in the solution. The difference is we are approaching with clear vision. You are approaching with bias.
/ B3030 #33
I'm only commenting on this thread because MJ said that his B3030 can't handle a rear snow blower. The blower on my B3030 worked fine last year when we got 30 inches of snow in one storm. In fact, it was a life saver!
As far as his mechanical troubles go, reason might be the fact that he has a crew operating it. Most people had yet to get a tool, tractor, or vehicle back as good as it was when it went out. Some times it isn't even from lack of caring or recklessness. I loaned my brother my chainsaw one time. He thought he would do me a flavor and get it sharpened by a professional shop before returning it to me. It was sharpened at the wrong angle and couldn't cut butter when I got the saw back.
Lesson learned: if you care about your equipment, don't let other people operate it!
/ B3030 #34
"Brand bashing has so far resulted in 32 posts and no answers. We are all interested in the solution. The difference is we are approaching with clear vision. You are approaching with bias."
True and I am reminded of the old saying, "you never get a second chance to make a first impression."
I am sure much more understanding and helpful posts would have been made if the OP was:
"I have a B3030 and need some help. The 4x4 doesn't work. When shifting, I can feel the gears shift in to each other. So I'm assuming the problem is after the transmission. Maybe a busted driveshaft, broken gear etc in the front end? I looked at an assembly diagram for the 4x4 system. It's over my head, lot of parts in there. Anyone know these tractors well enough to point me in the right direction?
I bought this tractor used and the rear tires with WATER. That's all well and good in warm climates, but the tires are frozen solid, literally. The thing has zero traction. I got it stuck in the grass today. Yes, stuck in the grass, not snow, not mud, but grass. So far problems encountered: Underpowered, poor performing hydro trans, weak loader, poor 4x4, hard to start, slow, underpowered 3 point lift ability. Comfy seat though."
/ B3030 #35
I wish the OP were close by. I am excited about problems like these. Within 15 minutes I can diagnose where his 4x4 problem is. And depending on location, within a couple hours have it exposed.
As for the hydraulic problem, that could also be diagnosed within 30 minutes. The fix there might become more complex depending on the problem. But he's already said he understands hydraulics to that would be a piece of cake for him to fix.
I'm curious about thes problems and look forward to hearing answers concerning the fix.
/ B3030 #36
I have a 60" Ecnor blower on my B3030HSDCC and it is a great set up. I think it handles the 60" blower better than my L3540HSDCC handles a 74" blower.
/ B3030 #37
Looks like another trolling episode...
Sent from my iPhone 5s 64Gb using TractorByNet
/ B3030
for those of you who actually gave me some decent info, I appreciate it. The rest of you can tune out now, thanks for wasting page after page of nonsense.
Haven't had a chance to diagnose the hydros yet. We got slammed with another snow storm. I did quickly check the 4x4 last time I had it out. picked the front end up. Tires were rotated by hand. When I spun the left tire, the right one spun opposite direction. When I spun the right tire, the left went in opposite direction, but at a noticeably slower speed. That's what's making me think the prob is in the front end, but that doesn't make a bit of sense to me. This is why I was hoping somebody could explain the front drive assembly on this thing. Do the gears need to be re-shimmed if they're pulled out on these or can they be disassembled and reassembled easily?
When I bought this from the Amish or Mennonite guy, whatever he was, I was hoping to possibly run a blower on it. But after seeing that it can't pick up a blade, there's no way it'll pick up a blower. This "dealer" is now out of business and nowhere to be found. Big surprise there. For those of you in CT, this is how those people operate, similar to gypsies. My mistake for dealing with him. Being in CT, I'm sure you have a large population of Amish and Mennonites so I bet you can relate.......
/ B3030
yeah there's a kubota dealer here in town but I don't like taking my stuff to a shop unless it's dire. We have a nicely equipped shop and do almost all of our repairs in house. I'm just leery about tearing into that front end. I'm in the process of working a deal to trade the 3030 in on a newer Bobcat tractor with 300 hours, that'd be ideal. This Kubota has been a hassle from the beginning. I'd certainly get more $ for it if it's working properly though.
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
Brady 12ft. Field Cultivator (A65640)
Brady 12ft. Field...
2002 CATERPILLAR 963C CRAWLER LOADER (A65053)
2002 CATERPILLAR...
LandPride Snow Plow (A62613)
LandPride Snow...
New Quick Attach Power Spreader (A65579)
New Quick Attach...
28 Gauge R Panels (A65640)
28 Gauge R Panels...
