B3030 rear remote problems ????? help!
/ B3030 rear remote problems ????? help! #1
hazmat
Elite Member
West Newbury, MA & Harrison, ME
Kubota L5460HSTC
Can't seem to get the hydraulic toplink to work.
It extended, but won't retract.
I re-jiggered (that's a highly technical term) the connections a few times. Figured perhaps there was a problem with the toplink so I swapped it out for the one that worked just dandy on my TC18. No dice.
Tractor seems to be going into bypass - the "power beyond' hoses for the backhoe get stiff.
Front loader & three point seem to be functioning normally. Fluid level looks good & fluid looks "right". I did notice that the hydraulic oil was especially hot after mowing the lawn. When re-attaching the FEL, I just about burned my fingers on the fittings. My TC18 never ran so hot.
Is there something stupid I'm missing? Tomorrow I'll try my dump trailer - It doesn't have the piloted check valve that the toplink cylinders have. Though I wouldn't expect that cause a problem, my TC18 had a 1,800 PSI relief setting, the B3030 should be outputting well north of 2,000.
I'll be putting in a call to the dealer tomorrow - hopefully one of their mobile service techs can get out to see it shortly...
/ B3030 rear remote problems ????? help! #2
Something is wrong here for sure. The backhoe hoses should not be getting stiff while running, do you have them connected? the system is under pressure and causing it to heat up from the resistance.
The backhoe hoses are connected.
They only get "stiff" when I try to operate the rear remote. Though the temperature of the hydraulic system has me a little concerned. If there were a restriction in the system, I'd think the other hydraulics would act funney?
/ B3030 rear remote problems ????? help! #4
Brand new tractor... this is a dealer issue! I would not touch anything.
mark
/ B3030 rear remote problems ????? help! #5
Temperature of Hydro oil will be about 100 degrees above ambient temperature. You will not keep you bare skin on it for long before it will become uncomfortable. :eek:
/ B3030 rear remote problems ????? help! #6
Sounds like one of the quick connectors needs to be replaced. You can't really tell by looking at them when they are apart if they aren't connecting correctly. I would say to try to see which side has the problem and change the set on that side. I had one last fall that did the same thing and I have seen others. It don't happen that often but it does happen.
I have 2 rear remotes - problem was with both remotes - that should minimize the chance of a bad connector right????
If the backhoe hoses are upstream of the rear remote (not sure if it is - don't have a schematic, haven't traced it out yet), it could get "stiff" if the flow was stopped at the remote - right? Leads me to an issue with the remote valve or associated plumbing & fittings.
/ B3030 rear remote problems ????? help! #8
Am I reading it right, that it is showing up with both remotes?
Problem solved I was plugging the lines into the fittings from each of the two valves despite the nice graphic directly above the outlets... :eek: :eek: :eek:
I'm claiming diminished mental capacity due to emotional stress - my 11 year old lab was diagnosed with a "mass" on his spleen yesterday:( . He's at the vet hospital right now for some tests - We'll know more tomorrow...
/ B3030 rear remote problems ????? help! #11
I'm happy you got it figured out and good luck with your best friend..
As I put her back into the garage last night I realized that when the ROPS is folded, it completely obscures the above mentioned graphic. The lines are so close together where they connect to the valves, that I had thought I traced them properly.
Perhaps I can re-apply to MENSA?:rolleyes:
2014 ALLMAND MAXI-HEAT PORTABLE HEATER / GENERATOR UNIT (A67714)
2014 ALLMAND...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
2023 WEILER K560 KNUCKLEBOOM LOADER (A65056)
2023 WEILER K560...
2017 Link-Belt 350X4 Hydraulic Excavator (A66734)
2017 Link-Belt...
2012 STEPHENS CRUDE PUP TRAILER (A67714)
2012 STEPHENS...
2022 CHEVROLET TAHOE (A66091)
2022 CHEVROLET...
