AZ ranch
/ AZ ranch
I finished with the floor boards. I will resume with the railing when I get back in a couple days.
/ AZ ranch #1,194
Looks nice.
Are you putting your corner railing posts on the inside of your decking, and the stair post on the outside? How will you line up your railing?
/ AZ ranch
What kind of chinking is that? Does it shrink much?
The chinking is concrete - 6 parts sand to 2 parts Portland cement to 1 part lime
This is one place where I disagree with the guy on Barnwood Builders - who says never use concrete.
It works, and is way less expensive than synthetic chinking. It does not shrink. The logs have shrunk a little bit over the past 5 years, so I am going around and sealing the crack with Permachink synthetic chinking. Much easier to squeeze it out of a tube for small cracks and not a huge financial burden when you just need it for cracks.
/ AZ ranch
Looks nice.
Good eye. I wanted the posts on the outside, and I will secure the cross pieces with either bolts or structural screws. I had two posts from the previous little porch that were on the inside corner, which I put up just to see what they look like. I think I will probably leave them there just to make it look tougher, stronger. I may run a screw through the end into the rail, or I may put a block under the rail and secure it to those corner posts. Either way they are not really contributing much to the strength. If they don’t look right, then I will take them out.
/ AZ ranch
Lime gives it more strength, adds a little flexibility, and adds a little bit of moisture proofing.
The downside is that it takes longer to cure. Today, time is money, so the faster concrete dries the better, but for my build, I didn’t care how long it took.
/ AZ ranch
I had hoped to make some progress on the deck railing, but with temps going down into the teens this week, I decided that stocking up on firewood was more important.
2006 Columbia Medical Transport Electric Utility Cart (A56859)
2006 Columbia...
TOYOTA 8FGCU30 FORKLIFT (INOPERABLE) (A60736)
TOYOTA 8FGCU30...
Toro z turn (A56859)
2008 MAXX-D FUEL TRAILER (A58214)
2008 MAXX-D FUEL...
2013 CATERPILLAR 416F BACKHOE (A62129)
2013 CATERPILLAR...
John Deere 3025E (A53317)
John Deere 3025E...
