Auto Darkening Helmets. Is there a difference?
/ Auto Darkening Helmets. Is there a difference? #41
I was pissed off today. Neither of my auto darkening hoods would work. One is the Jackson boss the other is a Lincoln. Turns out both had battery leakage issues. I cleaned both with battery corrosion compound and a tips. Both were very hard to reach the way there designed. Both work now, but I was wondering, would lithium batteries cause the same issue if I swap to lithium?
All batteries will probably have same issues, it is dissimilar metals against each other with moisture and oxygen present and voltage flowing through connection.... Answer is clean connections and add anti corrosion compounds (silicone based dielectric grease) which you have done...
Dale
I was at my friends place today. Ten was a gross underestimate. Probably twenty helmets lying around. Many Lincolns but the cheaper versions, not the Viking. They seem to find the cheaper ones quite satisfactory.
/ Auto Darkening Helmets. Is there a difference? #43
Love my 3M Speedglass.
/ Auto Darkening Helmets. Is there a difference? #44
I looked at a review and thought that I might have found a good helmet in the Lincoln Viking 3350. A little shocked at the price tag, but then of course that dream had to be blown up. My local Praxair dealer said he took them off the shelf after issues, which Lincoln refused to stand behind.
I've been really happy with my Jackson set up. The large viewing area is nice and i have not heard of any problems with the lens.
JACKSON SAFETY 46118 True Sight II Digital Variable ADF Welding Helmet with Balder Technology, Halo X and Scars, Universal, Stars: Amazon.com: Industrial & Scientific
Dale
Dale, here in north-central Minnesota and lacking a heated garage, I bring everything with a battery inside for the winter.
/ Auto Darkening Helmets. Is there a difference? #45
I've been using a $100 helmet from Lowes the past couple years. I got a Lincoln Viking 3350 for Christmas. I'll let you know the difference.
/ Auto Darkening Helmets. Is there a difference? #46
Please report back. I'd say that you were definitely on the "Good" side of Santa's list!
With all my projects, I am grimicing at the prospect of spending five hundred bucks on a helmet. But I think it does have much to do with ones eyesight. Like some people wear $15 glass and some 15 hundred! Not for style or name but for optical reasons.
/ Auto Darkening Helmets. Is there a difference? #48
I want to hear the rest of the story also. I too am using a helmet from Lowes and don't know enough about them to know if it is a bad-good-better model.
For what it's worth, I had been talking about peoples prescription glasses and wide cost variances.
/ Auto Darkening Helmets. Is there a difference? #50
For what it is worth, my older brother stopped by yesterday while I was making art out in the Tinkerage and he tried my Jackson W70 Truesight II helmet and instantly wanted one. My brother has been welding longer than I have.
/ Auto Darkening Helmets. Is there a difference? #51
For what it is worth, I haven't seen any optical differences in the high dollar Speedglas vs my $39 HF hood. The major thing with welding hood and visual deformities is in the quality of the clear lens used. A cheap clear lens will cause double vision or worse. If you use a quality clear lens, then you wont be troubled with visual issue with just about any self darkening lens. They all pass ANSI spec for UV light filtration and speed of reaction to darkening.
As for clarity of puddle, nothing beats an American Optical Gold Lens with super blue filter. If you can find one, I might be over $200 and it is a single shade lens.
/ Auto Darkening Helmets. Is there a difference? #52
My HF helmet is great. I've been using it for 3 years without issue.
/ Auto Darkening Helmets. Is there a difference? #53
I have a HF hood that is 10 years old. I finally took it out of service and started using my new HF hood. The old one got to where the battery wouldn't charge up enough for the glass to darken for a few seconds. After a couple seconds of welding, the UF light charged it up and it would work properly. I always hung it up next to the window so full sun hit it all afternoon.
I guess I will experiment with it to see if I can snap apart the lens to expose the batteries and maybe replace them (or not, $39 is not that great of a price so I might just leave it on the shelf for a while )
/ Auto Darkening Helmets. Is there a difference? #54
How often do you use it? I think my cheapo ($99) Miller autodarking helmet finally crapped the bed today. It notified me that the batteries were an issue Changed them and it still goes total dark now after battery replacement. I might be in the market for a 'better' one. Hard to justify as I am a hobby welder.
/ Auto Darkening Helmets. Is there a difference? #55
With the Jackson W70 lens, you get optically clear with a bluish tint in a large viewing area with an auto shut-off and grind, torch, and weld settings. Check out the video at 1:17 where it shows what you see when welding (too bad they couldn't put the camera at a different angle). Not that I've tried every welding helmet out there, but in my experience, I haven't seen better clarity.
/ Auto Darkening Helmets. Is there a difference? #56
Someone back a ways stated about cataract surgery. I noticed a huge difference after from prior. My doctor explained the cataracts reduce the light tat the iris receives so make sense. Made a big difference in night driving also. I have used my HF auto for 6 years now, never failed. use 9 or 10 depending on rod size. 5/32-3/16 takes the 10 and once in awhile 11. Mine does not activate in sunlight but does with a grinder. My welding is all SMAW and O/A so you mig & tiggers; I have no clue on your need. I have a new HF on the shelf for backup. Should use it once in awhile to assure it really is a backup. Have a couple old hoods gathering dust in the corner, candidates for the next big clean out. Always have and still O/A weld with #4 goggles. Arc length was mentioned as changing light strength. True, but extending the arc will produce porosity, scatter metal particles all over, and result in poor penetration (weak weld). You will know when the arc is too short as it will snuff out. Finding that happy medium is what practice is all about.
Like most on TBN I am not a production welder anymore so laying out big bucks for part time use isn't in my lexicon.
Ron
/ Auto Darkening Helmets. Is there a difference? #57
After a couple projects completed with my new Viking helmet. Here's my opinion:
1) My Kobalt helmet was a great deal at $100 4 years ago.
2) My new Viking helmet is very clear
3) My Kobalt was a great starter helmet and I'd recommend to any new welder
4) The Viking head gear is much more comfortable
5) I don't believe the Viking is 3.5 times better ($100 vs $350)
Conclusion. If this is your first helmet, get the Kobalt. When it finally wears out, you'll know if your ready for an upgrade.
/ Auto Darkening Helmets. Is there a difference? #58
Eric, no disrespect but that video was marketing genius/crap. 2.23minutes and mostly CGI (computer graphics imagery). A small amount of actual welding video and pretty much zero info other than the side by side comparison to... what?
I am a pretty much a believer of what you pay for but I want some good info on what helmet to upgrade to without breaking the bank.
/ Auto Darkening Helmets. Is there a difference? #59
I have one of the Jackson large window hoods, really liked it - it's still "OK", other than having to replace the guts at around $300 once - then I bought one of these (because of a thread here)
Antra Welding Helmet Auto Darkening AH7-86- Huge Viewing Size 3.86X3.5" Wide Shade Range 4/5-9/9-13 Great for TIG MIG/MAG MMA Plasma, Grinding, Solar-Lithium Dual Power, 6+1 Extra Lens Covers: Amazon.com: Industrial & Scientific
I've only used it a couple times, but it's a LOT clearer than the Jackson, and I could buy FOUR of 'em for the cost of a new cartridge for the Jackson. It's nice to have a second hood (#1 grandson things so too :thumbsup:
Guess what's gonna happen to the Jackson the next time it craps out :rolleyes: ... Steve
/ Auto Darkening Helmets. Is there a difference? #60
I really like this Tweco auto dark helmet. It’s very comfortable and is my “go to “. Please keep in mind these days most of my projects do not require extended hood time. Taking the lid on and off a lot is required.
IIRC the helmet was $600 but included a free welder.
JLG TELESCOPIC FORKLIFT (A64279)
JLG TELESCOPIC...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
2015 Gehl V270 w/ Bucket (A63688)
2015 Gehl V270 w/...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
2015 Deere 210G (A64126)
2015 Deere 210G...
