ATV forum
/ ATV forum #1
Deerlope
Northern, New York
Kubota L3830 03: RTV 900
I tryred to post in there and kept getting a window that said my message was too short and that I should add 5 characters. The more that I added did not make any differnence. I had 5 lines and finally said to heck with it and deleted the whole thing. Please fix it.
/ ATV forum #2
When something like that happens, try to copy the text to your clipboard, log out fo TBN and log back in. Then start a new post and paste the copied text into it and see if it works.
/ ATV forum
I type with 2 fingers and can barely turn on/off this computer, so knowing how to do the things that you have suggested are out of the question. If you can not see the problem from your end I can just go some place else.
/ ATV forum #4
As I suggested before, why don't you try logging off of TBN, then logging back in to TBN and try making a post in the ATV forum and see if that works.
I cannot see the problem from this end and no on else is reporting a problem with it, so the first assumption I am going to make is the problem is on your end. Perhaps you can take a class at a local community college in basic computer operation, or ask someone in your area that is familiar with computers to show you how to do a few things on your computer. Copying and pasting is something everyone should learn to do on a computer.
/ ATV forum
I just posted in the ATV forum and it went in. I did not log out as you suggested.
/ ATV forum #6
Then what did you differently from when you couldn't post?
/ ATV forum
I have no idea what is going on. Thanks for all the suggestions.
16ft Southland enclosed trailer (A64047)
16ft Southland...
2020 John Deere HPX615E Gator 4x4 Diesel Utility Cart (A61572)
2020 John Deere...
2025 HD Trailer Solutions EQ15 T/A Equipment Trailer (A59230)
2025 HD Trailer...
2000 CATERPILLAR 988F SERIES II WHEEL LOADER (A62129)
2000 CATERPILLAR...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
