Anyone recognize this part?
/ Anyone recognize this part? #1
IslandTractor
Super Star Member
Prudence Island, RI
2007 Kioti DK40se HST, Woods BH
This "came off" my DK40se/KL401. Any guesses?
Anyone else had this experience?
Answer: load level indicator. Not tough enough to survive backing it into a big tree branch. Tried to straighten it but the very tip ended up jammed in in the tube and the thing turned into a pretzle so I removed it. Now I have to decide whether it is worth replacing. I never really used it much.
/ Anyone recognize this part? #2
No fun, didn't get the chance to guess.
I use mine all the time, particularly when loading bucket and I don't want to dig into underlying soil.
Also use frequently when loaded bucket on pavement.
Joel
/ Anyone recognize this part? #3
Neccesary NO. Nice to have YES. Sometimes you just cant see the bucket.
/ Anyone recognize this part? #4
I use mine all the time. You might not use it now, but you might want it later on. Maybe put it back on once you finish working in all that brush.
I really don't do much bucket work these days at all. We have no pavement on the island but I may replace it someday down the road.
/ Anyone recognize this part? #6
How do you back something in to a tree that's on the front of the tractor?
:eek: 1) Drive under tree, 2) scoop load of debris, 3) raise bucket, 4) back out (while looking backwards), 5) snag level indicator, which is now the highest point on the FEL, on large overhanging branch. Taa Daa. It's not that hard. With a little practice you could probably do it too. :D
The described method only damaged the indicator by breaking off the top portion of the retainer tube and bending the rod. I pulled off the damaged retainer tube and straightened the rod except for a one inch segment at the very tip that I could not bend back (without removing the whole thing from the tractor that is). It seemed OK as a temp fix until on another occasion I did a full dump which allowed the bent tip to enter the lower portion of the retainer tube. I did not notice it but it jammed there so that when I curled the bucket it pretzeled the remainder of the indicator shaft. At that point it was hopelessly damaged so I took it off.
/ Anyone recognize this part? #8
Mine looked similar to that the very first time I used my tractor. Apparently there was a few defective outer tubes out there, I was playing with my brand spanking new tractor and bent the inner rod like a pretzel by working the bucket. My dealer promptly installed a complete new assembly.The new ones aren't painted orange on the outer tube.
/ Anyone recognize this part? #9
Mines pretty much destroyed too. Been thinking about replacing it for the fel work.
New/Unused Wolverine 66in Quick Attach Smooth Bucket (A65583)
New/Unused...
Giyi XKH39 Mini 4-in-1 Bucket (A64126)
Giyi XKH39 Mini...
2001 Blaw-Knox PF 150 Paving Machine  (A62679)
2001 Blaw-Knox PF...
Komatsu D65EX Dozer (A66285)
Komatsu D65EX...
White Oak Slabs (A65640)
White Oak Slabs...
2006 PROCO 130BBL (A65643)
2006 PROCO 130BBL...
