Anyone make a spline alignment tool?
/ Anyone make a spline alignment tool? #21
Considering this thread was started 9 years ago, there were a few developments as far as ease of hook up since then.
Here's one type of which there are a couple similar ones on the market:
/ Anyone make a spline alignment tool? #22
Yep, that's it. I'd like a tool that aligns the PTO to the coupler on the mower so when I do try to bring them together it's an easy fit. Is there such thing?
On my Kubota L3130 if I turn off the engine the PTO shaft can be manually rotated to line up the splines.
/ Anyone make a spline alignment tool? #23
None of those easy-peasy quick attach PTO adapters are cheap and all will require shortening the PTO shaft to accommodate them too.
To me they are an expensive solution looking for a non existent problem.
My stub 'wrench' is a greasy glove I keep in the tool box just for that task. besides, the greasy glove lubricates the stub.
/ Anyone make a spline alignment tool? #24
One thing that is unchanged and that is, you either have an ASAE 6 spline or an ASAE 21 spine rear stub and some older tractors have both (like mine).
/ Anyone make a spline alignment tool? #25
Looks like that would be only work if your PTO doesn't have a shield around it. Would be pretty awkward on my tractors.
Good point! Thanks for pointing that out.
/ Anyone make a spline alignment tool? #26
My only PTO implement - Wallenstein BX62S chipper. I have a strap - goes from the top link to the PTO shaft. Holds the shaft up while making final adjustments. Spin the PTO stub - pull back the collar - push it home.
I store the entire PTO shaft under cover in my one enclosed carport stall. Keeps it clean and ready to go when needed. I keep the entire shaft covered with a large towel to keep dust off. Every little bit seems to help.
UNUSED SDLANCH SDLGC80 ELECTRIC GOLF CART (A64280)
UNUSED SDLANCH...
(4) RUBBER TIRE LOADER TIRES (A62613)
(4) RUBBER TIRE...
17601CFL (A59228)
17601CFL (A59228)
(2) 25X10.00-12 TIRES W/ 4 LUG RIMS (A64280)
(2) 25X10.00-12...
Caterpillar 963 Track Loader Service Manuals (A63117)
Caterpillar 963...
PALLET OF INDUSTRIAL PAPER TOWEL DISPENSERS (A64281)
PALLET OF...
