Anyone make a spline alignment tool?
/ Anyone make a spline alignment tool? #21
Considering this thread was started 9 years ago, there were a few developments as far as ease of hook up since then.
Here's one type of which there are a couple similar ones on the market:
/ Anyone make a spline alignment tool? #22
Yep, that's it. I'd like a tool that aligns the PTO to the coupler on the mower so when I do try to bring them together it's an easy fit. Is there such thing?
On my Kubota L3130 if I turn off the engine the PTO shaft can be manually rotated to line up the splines.
/ Anyone make a spline alignment tool? #23
None of those easy-peasy quick attach PTO adapters are cheap and all will require shortening the PTO shaft to accommodate them too.
To me they are an expensive solution looking for a non existent problem.
My stub 'wrench' is a greasy glove I keep in the tool box just for that task. besides, the greasy glove lubricates the stub.
/ Anyone make a spline alignment tool? #24
One thing that is unchanged and that is, you either have an ASAE 6 spline or an ASAE 21 spine rear stub and some older tractors have both (like mine).
/ Anyone make a spline alignment tool? #25
Looks like that would be only work if your PTO doesn't have a shield around it. Would be pretty awkward on my tractors.
Good point! Thanks for pointing that out.
/ Anyone make a spline alignment tool? #26
My only PTO implement - Wallenstein BX62S chipper. I have a strap - goes from the top link to the PTO shaft. Holds the shaft up while making final adjustments. Spin the PTO stub - pull back the collar - push it home.
I store the entire PTO shaft under cover in my one enclosed carport stall. Keeps it clean and ready to go when needed. I keep the entire shaft covered with a large towel to keep dust off. Every little bit seems to help.
2022 EZ-GO ELITE...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
Deutz F3L914 3-Cylinder Air-Cooled Diesel Engine - 54 HP - Pump Takeout (A63689)
Deutz F3L914...
2020 VERMEER LP873SD1 VAC-TRON VACUUM TRAILER (A63276)
2020 VERMEER...
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A63689)
2021 Gehl RT215...
