Any secrets for removing Scag blades?
   / Any secrets for removing Scag blades? #11
Here's the deal. If you've hit something with your blades the nut has thereby tightened with that impact. With your Scag you'll have to use, in my case a 13" crescent wrench on top to hold the spindle nut from reversing. Then from underneath use a 15/16" (1/2" dr.) socket or a 24mm if you desire. Connected to a 24" breaker bar and a pipe of sufficient ID to accept the end of your breaker bar.
Physics comes into play here. The farther away from the axis (The stubborn nut/bolt) the less energy is needed to break the bond.
I keep a 4 foot long pipe around for just such occasions with my Ferris on the farm.
   / Any secrets for removing Scag blades? #12
I had to get an Ingersoll Rand 2135TiMax that was rated at 780 ft/lbs torque on reverse to get mine off, and that was after using a lesser 1/2 " air wrench. I even put a little grease on the bolt end last time. I will try some anti-seize compound next time.
   / Any secrets for removing Scag blades? #13
I replaced my spindle bolts and nuts yesterday and the Skagg dealer told me to put a thin washer under the top nut. I also put anti-sieze compound on it, so we'll see how it does.
   / Any secrets for removing Scag blades? #14
I have 2 Scag mowers, the first time I took the blades off was a learning experience. Now I use never seize and a impact gun. No problems now
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2021 Club Car Carryall 500 Electric Utility Cart (A59228)
2021 Club Car...
2009 CATERPILLAR AP1000D ASPHALT PAVER (A60429)
2009 CATERPILLAR...
2024 Timpte 40ft Hopper (A56438)
2024 Timpte 40ft...
2009 Ford E-450 Ambulance (A55852)
2009 Ford E-450...
2022 Schulte 2500 Giant Rock Picker (A56436)
2022 Schulte 2500...
