Any secrets for removing Scag blades?
   / Any secrets for removing Scag blades? #11
Here's the deal. If you've hit something with your blades the nut has thereby tightened with that impact. With your Scag you'll have to use, in my case a 13" crescent wrench on top to hold the spindle nut from reversing. Then from underneath use a 15/16" (1/2" dr.) socket or a 24mm if you desire. Connected to a 24" breaker bar and a pipe of sufficient ID to accept the end of your breaker bar.
Physics comes into play here. The farther away from the axis (The stubborn nut/bolt) the less energy is needed to break the bond.
I keep a 4 foot long pipe around for just such occasions with my Ferris on the farm.
   / Any secrets for removing Scag blades? #12
I had to get an Ingersoll Rand 2135TiMax that was rated at 780 ft/lbs torque on reverse to get mine off, and that was after using a lesser 1/2 " air wrench. I even put a little grease on the bolt end last time. I will try some anti-seize compound next time.
   / Any secrets for removing Scag blades? #13
I replaced my spindle bolts and nuts yesterday and the Skagg dealer told me to put a thin washer under the top nut. I also put anti-sieze compound on it, so we'll see how it does.
   / Any secrets for removing Scag blades? #14
I have 2 Scag mowers, the first time I took the blades off was a learning experience. Now I use never seize and a impact gun. No problems now
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
2010 Toyota Highlander SUV (A59231)
2010 Toyota...
2026 tilt trailer (A56859)
2026 tilt trailer...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
