Another Question about towing
/ Another Question about towing #1
JMHTX
Montgomery, TX
2014 John Deere 5055 E Cab
So.....I loaded my tractor on the trailer today for the first time. F250 Superduty 20' Bumper pull
Channel Iron frame and 2 7K axles. Butt down, nose up. Even setting the tractor back a bit on the trailer
still a little too much drop IMO.
Opinions on the best way to counter this. Air bags .. or a helper - leveling spring.
What should I expect to pay and which works the best.
Thanks
Jon
/ Another Question about towing #2
Lots of folks can help on this. Can you put up a photo of the truck with trailer and tractor on it?
That would help to zero in on solutions.
/ Another Question about towing #3
Yes, a picture would really help. Just as well what model tractor were you towing ?
/ Another Question about towing #4
You need some actual weight figures really. Gross weight of the trailer and tongue weight. With a bumper pull you should have about 10-15% tongue weight. Most 3/4 tons should be able to handle that without help, although airbags would be helpful.
/ Another Question about towing #5
I put air bags on my 2500 for towing my 5th wheel but now I wish I had put Timbrens on instead. They would have been a lot less work and about $500.00 cheaper than the bags with the compressor.
/ Another Question about towing #6
I agree pictures and weights would help but from my experience using a similar F250 and 20' trailer you should not need any extra bags or springs on the truck. I find the rear axle of the tractor should be just ahead of the trailers rear axle, depends on what is on the tractor (fel, heavy rear implement etc.). Having the proper hitch is more beneficial and important imo.
/ Another Question about towing #7
Does tractor have a loader on it? Good rule of thumb is to place tractor on trailer pointing forward and have the rear axle of tractor in between the trailer tandems. If there is still too much weight on truck then move tractor back on trailer until the rear axle of tractor is over the rear axle of trailer. If there is still too much weight on the truck you will to address the issue, but with a F250 you should have plenty suspension to handle this load.
/ Another Question about towing #8
Weight distributing hitch, the type with "lift or weight bars" with the bars rated for your tongue weight. If that is not enough helper leaves or airbags.
/ Another Question about towing #10
Don't know the year of your F250 but if the rear is sagging that much maybe you need to replace the springs. The 250 should barely drop at all if the springs are good. I have a 22' 14K trailer I tow with a half ton and the rear of my truck only drops an inch or two with the tractor loaded.
/ Another Question about towing #11
A little late to the party, but I agree with George. Up until a year or so ago towed almost daily with my '99 F350. At one point the rear springs began to sag with just the weight of the unloaded GN. There are a bunch of Super Duty's around here and most of them don't get used for more than daily drivers, so I got a set off of a wrecked truck and no more sag.
/ Another Question about towing #12
It might just be too much weight without a WD hitch.
Assuming its the 5055e in the avatar, those are 5500# bare tractor.
In another thread, he mentions no loader, but a LP 6' RFM, and is estimating 7800# for the package.
Depending on just where the axles are on the trailer, and how the trailer ramps are designed, You might not be able to get to what is acceptable. A 20' trailer for that sized tractor dont leave much wiggle room.
I agree with others, without knowing weights here, all we can do is guess. With the trailer weight, you are looking at a 10k total load. So you should need 1000-1500# on the hitch. If you are getting more than that, adjust the load. If you are in that range, THEN and only THEN look into other means to level out.
2008 Sterling L7500 Series T/A Vactor 2115-J6 Combination Sewer Jetter Vacuum Truck (A66736)
2008 Sterling...
ELECTRIC MOTORS, ELECTRIC PUMP (A64276)
ELECTRIC MOTORS...
3148 (A63117)
3148 (A63117)
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
2013 CATERPILLAR 259B3 SKID STEER (A65056)
2013 CATERPILLAR...
KOMATSU D51PXI-24 CRAWLER DOZER (A65053)
KOMATSU D51PXI-24...
