Another no forward or reverse
/ Another no forward or reverse
Just want to Thank Dart1917 for the replies and the help. Terramite seems to be up and running, reassembled motor and replaced hoses( number 6 and 12 according to parts list) still noisy but have been told they all are. no more high pitch noise and sounding like it is going to fly apart. So 10 gallon oil a filter and a screen clean and 2 hoses all seems to be well. did dig test and did not stall. Goes forward, reverse, hoe and bucket work. The hoses where 3/8 and 1/2 inch, the 3/8 hose was collapsed inside.
/ Another no forward or reverse #12
Hi I have the exact same problem that you had. I would like to start by replacing the hoses and filters.
My diagram numbers don’t match with yours. I have attached a picture of my diagram can you tell what hoses you replaced
I took a picture of the page from the manual I received with the machine. This is what I got the numbers from. Hope it helps. Mine is a T5B. The 6 I mentioned is not the one that goes to the drive motor it is the one that comes off the tee with the filter.
/ Another no forward or reverse #14
Glad to hear you got it going. I would've put money on #6 being the culprit but a bad restiction in any hose is gonna give you headaches.
/ Another no forward or reverse #15
T5c does not use hydraulic oil.It uses 15/40 motor oil.Contact Bobby Harper in WV. It distinctly says that in the paperwork that comes with the machine also.He worked for Terrimite.
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
2007 Frienghtliner B2 School Bus (A59230)
2007 Frienghtliner...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A56859)
2019 Harley...
2010 MULTIQUIP 25KW GENERATOR (A58214)
2010 MULTIQUIP...
2017 Ram 2500 4x4 Crew Cab Pickup Truck (A60352)
2017 Ram 2500 4x4...
