B7610 sudden loss of forward / reverse power
   / B7610 sudden loss of forward / reverse power
thanks for updating the thread. it is nice that it was a simple solution too bad you already had the axle out by the time you figured it out. must by industrial tires the carcass is so stiff it doesn't go flat even at 0 PSI.
My initial report of zero psi was due to a stuck valve. But it was very low as discovered by removing the valve.
I think an important lesson from this is to check tire pressures even if they look fine.
I feel very blessed to have been given the solution before tearing into it further. It took less than a half hour to get the axle back on.
2013 Yamaha YDREX4 Electric Cart (A56859)
2013 Yamaha YDREX4...
2020 Hyundai Santa Fe SUV (A56859)
2020 Hyundai Santa...
2019 WABASH DVLSHPC 53FT DRY VAN TRAILER (A59575)
2019 WABASH...
2023 Landhonor Square Hay bale Grapple (A57454)
2023 Landhonor...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
