Kioti Power Loss Continued...
/ Kioti Power Loss Continued... #1
wxtrendsguy
Breinigsville
Kioti
So I thought I had it figured out and changed all the fluids, filters and etc. However the problem still persists and I have been able to narrow down more details as I experiment with different things. So this is a 2014 DK45 SE with a cab and FEL. For 10 years I have been spraying the same vineyard rows using the same CIMA sprayer attached to the 3 pt and powered by the PTO. Earlier this summer I started to experience sudden drops in power with the PTO engaged at 540 RPM (2500 RPM engine speed) when going uphill, if I stopped forward motion the engine and sprayer would rev back to full RPM but step on the accelerator and she'd bog right down again nearly to a stall. So those are the symptoms.
Now since then we have changed out all the fluids and filters including the air filter. I have also tried numerous tests including running the tractor at 2500 RPM and running up and down the rows in both low and medium speed setting all while having the sprayer (turned off) on the 3pt. We have also hauled 1500lb loads of fruit on the FEL loader (no PTO). Driven the tractor in all speed settings at various speeds on flat ground and hills (no PTO). Ran tractor parked with sprayer and PTO on at full RPM. PTO and sprayer on driving downhill. PTO and sprayer on driving very slowly (<1 mph). Results from all these tests have not shown any lugging or loss of power.
The only test that seems to create the loss of power is if I have the PTO engaged and then both on flat ground and going uphill if I am moving forward at say 2-3 mph. I randomly experience this power loss and nearly to a stall where if I stop forward motion or turn off the PTO the power comes back. Really have no freaking idea at this point and not going to bring it to a dealer just to have them tell me there is nothing wrong. Help I need to spray for spotted lanternflys before they kill the vineyard.
/ Kioti Power Loss Continued... #2
Probably problem with the sprayer dead heading when pumping for one reason or another.
/ Kioti Power Loss Continued... #4
Did you test with different PTO implements or just the sprayer?
The sprayer is the only heavy user of the PTO at full RPM. Other implements I have run far slower RPMs and I doubt would cause the same issue...
/ Kioti Power Loss Continued... #6
Does it sound like the engine is laboring or over loaded when the engine RPM’s drop? If yes is there some condition when sprayer pump is trying to build more pressure than normal consuming more HP? That is what bullrog is referring to by “dead heading”.
No pretty much it just drops out, but there is one more thing to tweak on the sprayer,,,there is a screen filter inline with the pump and I should make sure thats clean and then just run plain water and see if the power fall off happens...maybe will try that tonight if I can get to it before dark.
/ Kioti Power Loss Continued... #8
If just dropping out I would suspect something more electrical or fuel related but no clue on what type of fuel delivery system that tractor engine has nor how or if some electrical control can limit engine RPM on that model.
Possible interaction on ePTO to throttle command?
/ Kioti Power Loss Continued... #9
What do you mean with sprayer dead heading? Never heard it put that way....
Something causing the pump to over load requiring more power as a result more strain on the tractor. Not familiar with the set up but seems you've covered everything else.
So to keep this thread alive...I have been troubleshooting this for the last few weeks and this is what we have done so far since changing all fluids and filters. Run tractor at 2500 rpm in low medium and high gear and no isseues. Loaded the front end loaded with 1500 pound bins and again no problem. Run the tractor up and down the hill with no pto engaged and no problem. Run the tractor up and down the hill with PTO engaged but no no attachment to any implements, again no problem.
Now attach the sprayer to the PTO. Run tractor at 2000 rpm with pto and sprayer engaged and successfully spray the vineyard up and down 40 rows in both medium and low gear, speed at maybe 2-3 mph (normal spraying speed) and no issue. Increase tractor rpm to 2500 which is needed for proper spraying speed of 540 on the pto and go down the hill and no issue. Same condition but come up the hill and after a 5-30 seconds, the tractor looses power and nearly stalls until I stop forward motion and it seems to recover power. Sometimes get to the flat top of the hill with pto and sprayer engaged and experience some gyrating power loss. Also went down the hill and at the bottom with no acceleration and tractor pointed downhill (very slight rolling foward motion) with pto and sprayer engaged and again we see gyrating power up and down.
Discussions with sprayer manufacturer says the only way the sprayer could cause tractor power to lug is if the bearings were failing, however it was also said that if the bearing were seizing up there would smoke and metal flying around. I removed pto shaft and can easily turn the sprayer shaft with no issues so its definitely not the bearings on the sprayer. The only other function on the sprayer is the fan belt but it that was slipping we would not be losing tractor power.
So I still believe the issue lies within the tractor hydraulics but not 100% sure...so still looking for suggestions...I believe this Kiot has an electronic engage pto clutch. But I have no issues engaging the PTO on;y when operating under load and especially going uphill. And yes I have checked the hydraulic fluid level...
/ Kioti Power Loss Continued... #11
There's also a PTO driven pump on that sprayer, no? That's what most here are pointing to.. You can run and drive just fine with no load, even with the PTO engaged because it takes very little of your HP to do so. You can also run the sprayer at a slightly reduced PTO RPM, and thus even less HP, with no apparent problems. This leaves something in the sprayer's pump as the most likely culprit.
Does it have a recirculation bypass?
The only other thing would be air/fuel, as in clogged filters, weak fuel pump, dirty injectors, etc.
/ Kioti Power Loss Continued... #12
Can you borrow a 3pth 5' or 6 foot brush hog from somebody to try on your tractor to see if that also affects your machine?
Yes the sprayer pump is PTO driven as is the fan. The pump is a centrifugal pump design and feeds both the spray nozzle assemblies and also tank agitation/circulation. The pump is meant to be maintenance free and according to the dealer if the bearings were bad the thing would be smoking and only getting worse. I do not believe there is an actual bypass, as the pump pulls the spray material from the tank through an inline filter and pressure regulator and then pushes to the nozzles or back to the tank. Everything on the sprayer seems to be working well.
I agree I think it could be in the fuel system going to have the sprayer overhauled this winter, then test again and if still screwed up the tractor will need to go to the doctor...though I may try some injector cleaner additives during snow plowing season...
Interesting idea, I'll have to ask one of my friends to see if they have one of them...
/ Kioti Power Loss Continued... #17
I would definitely try another large sttachment on your tractor to try and duplicate what is happening with your sprayer on it.
2019 BOBCAT E45 EXCAVATOR (A63276)
2019 BOBCAT E45...
3PT 10' Rolling Cultivator (A60462)
3PT 10' Rolling...
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
AGRI-CRAFT STAINLESS STEEL FERTILIZER TENDER (A63291)
AGRI-CRAFT...
2022 EZ-GO ELITE...
