Another Newbie looking to buy a tractor
   / Another Newbie looking to buy a tractor #122
I think you made a good choice. I dont think you will find many cases that it is too large, but you will have significant capability
Now playing the waiting game.....
Gonna be a long couple weeks
   / Another Newbie looking to buy a tractor #124
Hello MaineBarn - Strongly suggest you add the hydraulic thumb to your BH. Get it done now - you will thank us forever once you have it vs the mechanical.
It's not that Mech Thumbs don't work, its when you are digging and moving rocks - you want the thumb, then you don't to dig, then repeat that 5 times an hour.
I had a mechanical thumb for 10+ years and installed a "diverter valve" Hydraulic thumb which uses the bucket hydraulics with a diverter to run the thumb on the BH sticks vs a new valve and Hyd lines - It's $1500 for this setup roughly to do it later,
So get the dedicated thumb valve and foot control installed at the operators' station and spend $2K or more once now rather than adding it later.
Thanks Carl_NH
I'm not 100% sure I'll be requiring the hydraulic thumb outside of work near the lake. My house's soil has some rocks but nothing major. I don't think I'd be flipping between needing/not needing it a ton. More of an occasional use or if using the thumb, it would be consistently on.
That being said, any idea if Kioti makes a kit specifically? If not, pretty sure I'll have to do it down the road if it becomes necessary. The dealership said Kioti would void my FEL warranty if I had a bolt on tooth bar. Assuming if a hydraulic thumb didn't come from Kioti, they would not warranty the backhoe during that first year.
   / Another Newbie looking to buy a tractor #126
Wow - Kioti voids the FEL warranty if you install a tooth bar on your bucket? That's insane and never heard of that before.
On FEL buckets, get the bolt-on bucket edge for the HD bucket as it provides 3/4" of steel reinforcement to the front edge and you won't bend it digging rocks and roots.
As far as the Hyd thumb - yea you can add it later, but your dealer should know all about adding hydraulic thumbs to these machines.
But I am not sure you are dealing with the right people at the dealership if they tell you a toothbar on the FEL voids the warranty. https://www.kentonequipment.com/kiotitractorandattachmentwarranty
   / Another Newbie looking to buy a tractor #127
I could see a ratchet rake voiding a loader warranty, as users back drag with the bucket curled down and the rams extended (bend prone). A tooth bar actually diminishes the force needed to push into soil/gravel/sod.
Agree 100%. I did get the cutting edge. I had sent a link to the Piranha bar and said was looking for something like that in addition to the cutting edge. Didn't care the manufacturer. That's where they said it wasn't allowed. I think he's referencing:
"C. The General and Extended Warranties do not cover the following:
3. Damage caused by the use of any non-KIOTI front-end loader, backhoe, attachment, implement, accessory or part. "​
Makes no sense to me as the tooth bar would protect the bucket.
I'll reach out and ask what the upcharge is for the hydraulic thumb would be. The mechanical one was priced at something like $300 (it was in a line item with multiple things and backing out the other stuff came to that I believe).
   / Another Newbie looking to buy a tractor #129
"Voids warranty on the Bucket", whatever. A bucket can be replaced for like $1200, so as long as it doesn't void warranty on the machine or the loader, I wouldn't worry.
Arrived today. The tractor/loader/backhoe got dropped off around 1:30 and the attachments around 4:30. Was working from home today so got a bit of time to play with it before it got dark. Not really a lot of stuff to do at the moment. Not enough snow to dig in and no soil I want to dig until spring. Going to attach/detach quick attach items, work on pallet pickup skills, test everything, and try to figure out the best places for front and rear cameras.
The visibility with the pallet forks is rough. Even the driver struggled to get the pallets off the trailer. Feels like a camera and practicing will make it much easier. Loving the cab space and how stable the machine felt going over a limited snowpack. I got loaded tires and also had them flip the wheels so they're as wide as possible.
The sound quality is terrible but the radio does a great job with the bluetooth connection. At one point I left the tractor running to go grab something around the house. Got back in the cab and realized a few seconds later that the phone paired back immediately and was playing music. New speakers and we'll be in business.
Much thanks to everyone who chimed in here. I ended up getting a machine that I've accepted may not be able to do the woods trail, might be able to make some progress on it before/after the fact, and definitely will meet all my needs for regular at home projects.
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
HOSHIZAKI ICE MAKER & ICE STORAGE BIN (A57192)
HOSHIZAKI ICE...
UNUSED FUTURE FT-72 72" HYD MULCHER (A57193)
UNUSED FUTURE...
2015 Peterbilt 567 (A55973)
2015 Peterbilt 567...
2025 Swict 66in Bucket Skid Steer Attachment (A55851)
2025 Swict 66in...
UNUSED WOLVERINE MCB-11 48W 48" HYD 4N1 BUCKET (A57193)
UNUSED WOLVERINE...
