R4sWhat tires did you get?
Now playing the waiting game.....I think you made a good choice. I dont think you will find many cases that it is too large, but you will have significant capability
Thanks Carl_NHHello MaineBarn - Strongly suggest you add the hydraulic thumb to your BH. Get it done now - you will thank us forever once you have it vs the mechanical.
It's not that Mech Thumbs don't work, its when you are digging and moving rocks - you want the thumb, then you don't to dig, then repeat that 5 times an hour.
I had a mechanical thumb for 10+ years and installed a "diverter valve" Hydraulic thumb which uses the bucket hydraulics with a diverter to run the thumb on the BH sticks vs a new valve and Hyd lines - It's $1500 for this setup roughly to do it later,
So get the dedicated thumb valve and foot control installed at the operators' station and spend $2K or more once now rather than adding it later.
Agree 100%. I did get the cutting edge. I had sent a link to the Piranha bar and said was looking for something like that in addition to the cutting edge. Didn't care the manufacturer. That's where they said it wasn't allowed. I think he's referencing:Wow - Kioti voids the FEL warranty if you install a tooth bar on your bucket? That's insane and never heard of that before.
On FEL buckets, get the bolt-on bucket edge for the HD bucket as it provides 3/4" of steel reinforcement to the front edge and you won't bend it digging rocks and roots.
As far as the Hyd thumb - yea you can add it later, but your dealer should know all about adding hydraulic thumbs to these machines.
But I am not sure you are dealing with the right people at the dealership if they tell you a toothbar on the FEL voids the warranty. https://www.kentonequipment.com/kiotitractorandattachmentwarranty
Read this thread and would like to offer my perspective as I have cut a 1000' elevated driveway thru a rocky tree wooden swap 18 years ago.Thanks Carl_NH
I'm not 100% sure I'll be requiring the hydraulic thumb outside of work near the lake. My house's soil has some rocks but nothing major. I don't think I'd be flipping between needing/not needing it a ton. More of an occasional use or if using the thumb, it would be consistently on.
That being said, any idea if Kioti makes a kit specifically? If not, pretty sure I'll have to do it down the road if it becomes necessary. The dealership said Kioti would void my FEL warranty if I had a bolt on tooth bar. Assuming if a hydraulic thumb didn't come from Kioti, they would not warranty the backhoe during that first year.
