Another New Guy Question-Radiator bottle?
/ Another New Guy Question-Radiator bottle? #1
samisam
Keithville, La.
1300D
As previously posted, I have just purchased a 1300d and noticed when I shake the front loader a little anti-freeze comes out the tube to the ground. Is there an overflow bottle available for this unit or is the anti-freeze supposed to run to the ground instead. Not that this is a major deal but eventually I guess I will have to add some at some point if there is no bottle made for this unit.
As always, Any input is appreciated.
Samisam
/ Another New Guy Question-Radiator bottle? #2
There are overflow bottles available for everything at auto parts stores.
/ Another New Guy Question-Radiator bottle? #3
Shaking / using the loader, or any other activity, won't cause the Coolant to come out from the
"Overflow" tube. A Radiator cap that is weak,not holding enough pressure, not fully tighted, or too
short, will however cause this leakage. A "Overheated" engine will also. An Overflow jug can be added,
but it's really just for convienence. As long as you keep coolant in the jug, most people never open the
radiator to check the level. Without the Overflow jug, the Manuals say to check the coolant level, and
all the other Fluid levels, daily, before useage. This is from the 155d books, as well as other operator
manuals I have seen.
I have found that keeping the radiator full keeps the Thermosiphon system happy. If the level
is more than an inch from the top, the "flow" is noticably reduced. Anytime the top neck of the
radiator is lower than the water outlet of the engine, as in facing downhill, also slows down the
Thermosiphon action. They will overheat if the slope is steep. The belt must be tight also,for the
fan to draw enough air. At the higher rpm's,above 1,800, they need the additional airflow to cool
the radiator core. Keep the Debris Screen and the radiator Fins clean. They can get plugged up
Really Quick, depending on what get sucked up into them.
I connected a jumper wire from the Temp sender to the Horn on both of mine as a Audible alarm.
To test the Temp lamp,push the horn button. This feature works very well while facing backwords
watching an Implement, or on the Backhoe.
Hope this wasn't too long winded..............Lloyd
/ Another New Guy Question-Radiator bottle? #4
I have a YM1110D which didn't have an overflow bottle. Like your 1300D, it also doesn't have a water pump. So I made an overflow bottle using a small bottle, some tubing, and hose. I also made a bracket to mount it under the hood. And believe me, there isn't alot of space under there. If you do this, you must replace the radiator cap with one designed for an overflow system - they are different. Also make sure to get one with the same pressure rating (should be 13psi).
I attached a photo of my overflow system.
/ Another New Guy Question-Radiator bottle? #5
I got a 9$ universal kit from car quest for my 1700.. hung right above battery.. worked great.. never have problems with it..
Do check your radiator cap though.. this should be a recovery system.. sounds like your cap is not seating..
Soundguy
/ Another New Guy Question-Radiator bottle? #6
Nice neet job, Greg!
Peter
2020 WIRTGEN WR200 XLI SOIL STABILIZER (A62129)
2020 WIRTGEN WR200...
2025 Pabreak 6-Way 84in. Serrated Hydraulic Dozer Blade Skid Steer Attachment (A61567)
2025 Pabreak 6-Way...
2011 JOHN DEERE 710J BACKHOE (A65053)
2011 JOHN DEERE...
2024 Ford Explorer SUV (A61574)
2024 Ford Explorer...
2006 Dodge Ram 1500 Pickup Truck (A61568)
2006 Dodge Ram...
1999 Sterling Dump Truck (A66285)
1999 Sterling Dump...
