Another Mini-Dozer
/ Another Mini-Dozer #281
Rawinok2 -
First things first - incredible build, especially with the challenges you face. My hat's off to you.
I'm wondering if part of the trouble is that the track tension springs aren't stiff enough. The adjustment on the original Struck's was just a threaded rod (and frame flex) - pretty stiff, in any case. Similarly the Bolens Hus-Skis, an early "snowmobile" (of sorts). Can you have someone eyeball the tension mechanism while you shift into forward and reverse, the next time you run it, to see how much things move?
I wouldn't worry as much about the drive sprockets being the front ones, since almost all modern "fast" track layers (main battle tanks, for instance) have the drive sprockets in front. "Slow" track layers do usually have the drive sprockets at the rear (or up high) to keep the portion of the track which is in contact with the ground in tension (that whole "you can't push a rope" thing). The fast track layers are keeping the lower portion "limp" so that it can be more compliant over bumps and hummocks at speed. Horses for courses, as they say.
In either case, you aren't likely to be having issues due to the fronts being the driven ones, but I could imagine it's a bit difficult to "modulate" the controls if the sprockets are "walking" back and compressing the tensioning springs as soon as you try to move the tractor. If that seems likely to be the problem, I'd try cobbling something to "lock out" the spring motion (temporarily) and see if it behaves better. If so, using stiffer springs might be all the medicine it needs.
Again, great job on the build.
Kevin
/ Another Mini-Dozer #282
Rawinok2 -
Kevin
I think you mis-understood, the fronts are not drive they just look the same as the rear.
/ Another Mini-Dozer #283
Its not PUSHING a rope... its just pulling from the other end. When the drive sprockets are rear, the upper portion of the track tense just like the belts on old fashioned threshers: by the weight of the belt which hangs down between the sprockets and two or three idlers. also this allows for better track to sprocket contact, as a too slack track hanging down, will increase the contact arc on the drive sprocket. If it hangs slack on front, the contact arc will decrease and there is more chance of skipping teeth
Fast crawlers have drive sprockets up front so they pull the upper part of the track tight to reduce harmful vibrations at high speeds, caused by the polygon effect of a sprocket, which isnt round like a belt pulley, but transmits torque in several little jerks, as many jerks per rotation as there are teeth on the sprocket wheel. (imagine a V belt which bends in a perfect radius around the pulley, but a chain bends in several sections around a sprocket: this means the actual radius of the sprocket depends on sprocket tooth position, in relation to the horizontal part of the chain) the polygon effect is well known in chain drive applications, and limits the length of which a chain can run unsupported at a certain speed.
the track tension on the part that touches the ground is the same, but the part which is above ground keeps better tension when the drive sprockets are on the ground, reducing the polygon effect at high speeds.
/ Another Mini-Dozer #284
Happy New Year Bob!!! How are you feeling after the holidays? Good I hope.
I do have a question if you would. What size dia. are the track wheels and the bogies? And you used a 6" channel correct? Sorry if I asked this before.
Dont bother getting out to the shop for dimenions. Save your energy. Just what you can remeber off the top of your head.
Thanks and hope to see back at it soon,Chris
/ Another Mini-Dozer #285
Your project is amazing. I weld/fabricate for a living so I have an idea as to what goes into a project like that. You had mentioned finding the chain that Struck used on the original. Here is a link to some. Tisco Tractor Part Mart: Reliable Tractor Parts You Need. Fast :: ATTACH LINK (55K1) It is a bit expensive though. As for the hydraulics the jack shaft is an excellent idea. The majority of hydraulic pumps out there are only rated for 1200rpm. Most gas motors turn 3600 rpm I believe. That will eat a pump pretty quick. My idea is to use a power steering pump. They will only develop about 1200psi but for your needs I would like to think that it would be adequate. GM has a power steering pump that uses a remote reservoir. I feel that would work well because you would be able to use a large reservoir and you could mount it were ever you wanted. Hydraulic hose ends that will screw into a power steering pump are available. Good luck on getting it were you want it. Once again great JOB!!!
/ Another Mini-Dozer #286
I've ordered some parts but that's about it.
Last weekend was not a good one for me. You may remember that I wrote about my accident at work which left me disabled (page 12). Well, I had another incident where my ankle started bleeding and would not stop until I lost a couple pints ! It was just getting started in the photo below. I usually have to get down on the floor and raise my ankle above my heart in order to get it to stop. The garbage bag catches most of the blood. I will probably be inactive for a few weeks trying to regain my srength.
It will probably be after the holidays before I post again. So you all have a great holiday season ! :)
OMG!
First, I hope you get well soon. Your health must come first!
Second, that is Great that you are documenting this for all of us to see. Thank you!
Third, the Project is is getting there and is awesome...
Can't wait to see it done!
Sorry I took so long to answer. My condition has gotten worse.
My ankles and feet are loaded with painful ulcers and I just had another bleeding incident yesterday. The good news is I finally found a doctor (a dermatologist) that has taken a real interest in getting me fixed.
The track wheels or sprockets are 12" diameter and the bogies are 4".
The channel is 6".
/ Another Mini-Dozer #289
The channel is 6".
Good to hear you found a doctor that really wants to help.I am trying to get a few medical issues taken care of myself.I can't find a doctor I can afford.
/ Another Mini-Dozer #290
Our family's prayers go out to you and yours. Get well soon.
/ Another Mini-Dozer #291
The channel is 6".
Not giving medical advice...
Could the cause be environmental?
My cousins husband is a tank fabricator... does beautiful food grade stainless work.
He developed an allergic reaction to Nickel that is found in Stainless... all those years of welding, grinding and polishing...
His condition greatly improved now that he is an estimator... he sure does miss building things!
/ Another Mini-Dozer #292
The channel is 6".
Hope the new Doc gets you back up and running and you get better soon!
/ Another Mini-Dozer #293
The channel is 6".
Did you have the problems with the legs before getting into electric that injured your shoulder or has it started since the incident at work? I was just a wondering because if it started afterward then maybe it is a further complication from your original injury. If it started afterward then maybe you also have some heart damage and circulatory injuries. Your mini dozer build looks good. Hope your health improves.
/ Another Mini-Dozer #294
From an earlier post - I think it started when the doctors harvested skin for grafts up above that didn't heal properly afterward.
I don't think it could be. I am not welding or cutting anything exotic and I have been welding off and on for over 35 years.
Thanks !
The ulcers started about a year after the accident which was in November of 2006. At first they were just on my lower legs which as "psdx" has pointed out was an area where they harvested skin from for grafting on my face, arms and torso. The ulcers cleared up for the most part on my legs but then migrated to my ankles and feet. Then, about a year or two ago (the accident gave me brain damage which affects my memory) I started to get these purple dots on my feet which seem to randomly burst and squirt unbelievable amounts of blood.
The dermatologist has made a preliminary diagnosis of "Blue Rubber Bleb"!
The name sounds like a joke but it is a real condition. I really don't think that most of the usual symptoms of this affliction fit me though. I'm sorry if these photos gross you out but I think one must see to believe. Whenever I start to bleed I put a garbage bag around my leg and make my way upstairs to the bathroom.The congealed blood around my foot in the photos is from me dumping the bag after about 3 to 4 minutes of bleeding. It is amazing how fast it congeals ! If you enlarge the thumbnails you can see the tiny stream of blood.
Thanks, you are correct !
/ Another Mini-Dozer #297
...I hope this new doctor can make something happen to control that at least.
Me too. I'd be afraid to leave the house if I had something like that to deal with.
I was in an elevator this past August with my wife and an elderly lady when it happened. I was wearing sandals and no socks. You talk about freaking someone out !!..:shocked:... Now I wear plastic bags under my socks ! :eek:
Sorry, I didn't really think about what you were saying when I posted that lame answer in my 2nd from last post. You may have something there. Even though I've not welded stainless in about 30 years (I nearly forgot about that), I still may have developed an allergic reaction to say....the fumes from the mild steel welding rods or the dust from the grinding wheels. Thanks for the food for thought ! BTW What was your cousins husband's symptoms, can you say ?
/ Another Mini-Dozer #300
Good grief RAW...that's a **** sandwich you don't deserve. I hear you on trying to find a good specialist as I'm trying to find one for a totally different condition than yours.
I used to have a protruding mole on my chin. One night before a date I nicked it with the razor...the dam thing wouldn't stop bleeding for about an hour. After it healed, I grew a beard. When I got tired of the beard, I had a plastic surgeon remove the mole.
The ulcer photo reminds me of the leg ulcers a brittle diabetic college buddy used to get on his legs. They would ooze blood now and then.
