Another dual blade grader idea....
   / Another dual blade grader idea.... #1
montejw
NW WA State
1980 AC 5020
I've already spent the money on a box blade, now I figure I really need(ed) a dual blade grader. With the box blade it seems like I've already got most of the pieces needed to build a dual blade unit, 2 blades, 3 point hitch and structure, 2 box sides. Just need to lengthen the sides, add bottom runners, and move the blades. Right? :confused:
Monte
   / Another dual blade grader idea.... #2
Sounds doable monte.
There were some threads about home made jobs about a year ago or so. Do a search and see what you come up with.
I've seen a few of the built from scratch dbg's, haven't found a stretched box blade one though.
Monte
   / Another dual blade grader idea.... #4
the comercial version is called Grademaster.
seems simple enough to build...
GradeMaster Manufacturing & Sales
   / Another dual blade grader idea.... #5
Not sure if this is what you are looking for but here is one approach I saw here on TBN...sorry I forget the original poster so cannot credit him.
   / Another dual blade grader idea.... #6
You could add some guage wheels to the BB and just make two passes.:D
Yeah, I've seen those and the Dura-Graders. More money than I want to spend right now. Trying to figure if it's worth modifying my BB since it's here and paid for.
Monte
I've seen another like that. I haven't gotten into adding additional hydraulic circuits yet. Those look like they'd work pretty well.
Monte
That's another approach I suppose. The dual blade units look a little simplier though. But then again, maybe I'm being simple. :rolleyes:
Monte
   / Another dual blade grader idea.... #11
Those graders seem awesome! Any ideas on prices?
With the specs, it should be pretty simple to duplicate. Does anybody have one?
   / Another dual blade grader idea.... #12
The name on the stone marker in the 4th picture says Trumpp.
   / Another dual blade grader idea.... #13
   / Another dual blade grader idea.... #14
Monte,
Reading these threads, if one already has the box blade, it would be pretty simple to mount a 2nd blade near the front of the side panels, at an angle. It could bolt on to the side panels for easy removal for normal box blade use. If I were doing it, I'd get some 3x5 angle iron, weld some plates on the end, drill holes through the end plates of both, and bolt it on. A cutting edge could then be bolted to the angle, as in the other posts.
I suspect gage wheels would add more benefit--and I'd likely do that prior to adding a 2nd blade.
But I'd not want to cut up my good box blade to make something new........
Hope this helps.
ron
   / Another dual blade grader idea.... #15
I've seen the Grademaster in use and it's pretty impressive. Nothing like a boxblade, and probably nothing that you can use in a boxblade to make one. Two different animals that have completely different designs. Trying to convert the boxblade sounds like a loosing battle.
I'd sell the box blade and buy the steel to build the Grademaster properly and not waster your time doing a half way type job.
Another company to look at for ideas is Roadrunner Construction Equipment - Out Performs Complex Motor Graders on Many Applications. They have a video that they will send you if you fill out the form. I haven't, but it might be worthwhile for you.
Good luck,
Eddie
Good luck,
Eddie
Seems to me like there's quite a bit useful in a box blade that's useful. 3PH structure, 2 "blades", and the sides that can be extended with a little more material. Guess it depends on how much the steel would cost for a grader from scratch and the resale value of my box blade. Haven't researched either one.
I think I ordered a video from one of the grader manufacturers. I hope to see the difference it makes installing the blades straight across, or angled.
Monte
2018 VOLVO L180H WHEEL LOADER (A60429)
2018 VOLVO L180H...
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
2016 JOHN DEERE 35G EXCAVATOR (A60429)
2016 JOHN DEERE...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
CAT 336E (A58214)
CAT 336E (A58214)
