Another Chain Box/Tool Box
/ Another Chain Box/Tool Box #1
3RRL
Super Member
Foothills of the Giant Sequoia's, California
55HP 4WD KAMA 554 and 4 x 4 Jinma 284
Thought I'd share this chain/tool box addition.
After installing one of Larry's ammo boxes on Loretta's Jinma, I had to install the other one on my Kama. Mounting it low on her tractor, and using it several times already, it was really easy to get chains in and out of these dual lid ammo boxes. The low mounting makes it so easy to get the chains back INTO the box. No more lifting them way up high into my old wooden chain box.
Some of you may have already seen Loretta's chain box?
I posted photos of the installation in another thread. Open the bottom lid and the chains drop out. Mine work the same way (of course).
Hers are the first set of photos and mine are the second set.
Rob-
/ Another Chain Box/Tool Box #3
Good idea. But then, all of your ideas are good. Don't stop sharing and thanks again.
/ Another Chain Box/Tool Box #4
Excellent ideas and fabrication work. :D I would have copied your idea, except my tires width is the same as the fel. I see that you would have no problem since the box looks like its at the same width as out side of your tires so that makes a very neat appearance. (can you tell i am already jealous ;)) :D Again - nice work !
/ Another Chain Box/Tool Box #5
Very good idea. The feature I like the best is how the chains can drop out the bottom. Nice job!
/ Another Chain Box/Tool Box #6
Is there a link where I can order the boxes? Or do you have the secret hookup? :)
/ Another Chain Box/Tool Box #7
I love the "MRS 3RRL" stenciled on Loretta's chain box! Not there was any question before about whose tractor it was, but it's sure in no doubt now! Fabulous work as usual, Rob!
Hey guys, thanks for the compliments!
Not only do I love that the chains fall out the bottom, but putting them back in is super easy now. The mounting bracket is all thick steel so it is very very strong. If you're going to make a bracket, I strongly suggest you use the one bolt clamping flange. It is very simple yet strong.
Thanks again for those ammo boxes Larry. They truly are very neat.
Yes, I'm running out of steel except I still have some set aside for other projects. There is still alot of steel on Fergie that I can use. It's an old Ferguson tractor that came with a top mounted sickle bar mower for orchards. I got it free as a scrap tractor. I am very frugal and have saved scrap for years... even little bitty pieces that I use for spacers or what not. I always try to recycle my scraps form one project and turn them into another useful item.
(lol ... Chips are a last resort :D)
My buddy Paul on another forum found some ammo boxes like these.
Here's a link to them: 25MM Ammo Box
He said sometimes they're available here so contact them for this specific 25MM one: Other Ammo Boxes
/ Another Chain Box/Tool Box #10
Is that a gold tractor???? If yes, first gold one I've ever seen!
2015 John Deere 8270R (A64119)
2015 John Deere...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59911)
2016 FREIGHTLINER...
Informational Lot - Financing (A63688)
Informational Lot...
2013 FREIGHTLINER Cascadia (A63689)
2013 FREIGHTLINER...
2007 PETERBILT 340 ROLL OFF TRUCK (A59909)
2007 PETERBILT 340...
2016 CATERPILLAR 308E2 CR EXCAVATOR (A64279)
2016 CATERPILLAR...
