Alternative Energy projects
/ Alternative Energy projects
I found out about these better mouse-traps today....
"Whirlpool Duet WD99HEDW ventless heat pump dryer, while LG sells the DLHX4072W".
Whirlpool® HybridCare
I didn't know that configuration of dryer was on the market. Big laundry loads in a high kwh market might make that worth a look.
Rgds, D.
/ Alternative Energy projects #43
Rgds, D.
I suppose it needs a condensate drain--like a mini-split? The water has to go somewhere. Normally the washer drain would be nearby so that may be no issue.
I haven't seen the installation details on these Dave, but that would be my guess too. On new installs, you'd have one less (vent) hole through the wall, as a bonus.
Rgds, D.
/ Alternative Energy projects #45
Rgds, D.
Yep, getting rid of the vent piping and hole could be very useful in most cases.
/ Alternative Energy projects #48
For further study: non-vented propane fridges.
Propane Refrigerators for Solar & Off Grid Homes
Rgds, D.
The 18 cubic feet frig says it uses 1.8 lbs of propane in 24 hours. The conversion factor for a gallon of propane is 4.22 lbs.
1.8/4.22 = 0.4265 gallons per day. At $2.25 per gallon that's $0.96 per day.
I've known a few off-grid folks with a propane frig and freezer. There are also kerosene refrigerators used by the Amish mostly.
https://www.lehmans.com/p-3505-dometic-kerosene-refrigerator.aspx?show=all
/ Alternative Energy projects #50
I've been impressed with the RV propane fridge/freezer units I've used. Stands to reason, that system could be fired with Natgas.
https://www.lehmans.com/p-4427-dometic-natural-gas-refrigerator.aspx?show=all
AC Sunfrosts are pretty efficient. If I was going to spend that kind of money, I'd be tempted to go DC - one less conversion in an off-grid system, and easy to time-shift battery charging when using TOU grid power.
Refrigerators & Freezers - SunFrost.com
Rgds, D.
I would prefer electric, DC or AC, over gas off-grid. It just seems easier than keeping a propane tank filled and the energy cost is fixed at the time you buy the off-grid system.
I agree, for totally off-grid. I'll probably go DC (even on-grid), if I get a Sunfrost.
I'm on-grid presently, so Nat-gas was on my mind. As food refrigeration is one of the major non-discretionary energy expenses, I'm also curious in general as to why Nat-gas fridges are not common. It is a simple design that tends to run almost forever (maybe a clue there ? ;) ), and if you have Natgas in the house already, that gets you around the propane re-supply issue/costs.
I see no technical reasons for Nat-gas to be not used for on-grid refrigeration...... just musing aloud here in case I missed something....
Rgds, D.
/ Alternative Energy projects #52
I don't see any reason to go completely off the grid, but I do see a lot of advantages to decreasing my dependency on what I use from the power company. Same thing with food. The more I can provide for myself, the farther my dollar will go and the better my standard of living will be. One of my future projects will be a solar well to water the garden.
Eddie
Any LP fridge or freezer will operate just fine on NG with a larger gas metering orifice.
Household natgas pressure is low, so that makes sense.
Rgds, D.
Eddie
Those are good points Eddie, that sit well with many people that hang out here. Post about what you use in the garden, that would be popular.
People have various motivations to go totally off-grid. The classic (and still valid) one was building on a remote site - even years ago, the cost to run a line significant distance was high, and has only climbed higher in recent years.
More recently, some jurisdictions have come to treat electricity as a license to Tax, or Pillage, depending who owns what..... quite the cost range shows up in the What on Earth does electricity Cost near You ? thread.
Rgds, D.
/ Alternative Energy projects #58
Wind and solar are intermitant and require energy storage . Energy storage per Kw hr is expensive, requires service , has chemical and environmental hazards. Bulky and heavy. All backed up with a diesel or gasoline generator .
Most "green" energy projects use fossil propane or natural gas . To carry the high demand loads of a refrigerator , stove, water heater, clothes dryer and central heat.
The definition of a green energy building is rather flexible.
Operation of a shop or business on "green" is even more daunting .
About the only place where solar assist to clip peak power from 9:00AM to 3:00PM are applications without the untility having sizable base load 24/7 generation. Hawaii comes to mind with diesel gen sets, gas turbines , limited hydro electric and extremely high utility rates.
/ Alternative Energy projects #59
...while waiting for cheap, fast, high-capacity battery technology.
There are and will not be cheap high density batteries unless the Almighty adds some new elements to the periodic table. There is lead, NI-MH and lithium for portable energy storage. Sodium may have a place for stationary applications .
Engineering firms will keep making promises and press releases about the next generation battery just around the corner. Of course they will as they make a living from research grants .
The next generation energy storage will have to be as different from a horse is different tech from a tractor .
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
2021 JOHN DEERE 410E SERIES II OFF ROAD DUMP TRUCK (A65053)
2021 JOHN DEERE...
2017 Volvo VNL T/A Sleeper Cab Truck Tractor (A66736)
2017 Volvo VNL T/A...
500 GAL WATER TANK (A68842)
500 GAL WATER TANK...
PORTA POTTY (A68842)
2006 PETERBILT 379 (INOPERABLE) (A67714)
2006 PETERBILT 379...
