Air tools w/ small compressor?
/ Air tools w/ small compressor? #1
N80
Super Member
SC
Kubota L4400 4wd w/LA 703 FEL
I need an impact wrench to remove lug nuts. A good cordless 1/2" one would be ideal but run $250-$300. (I want one for various reasons and plan to get one but it just isn't in the budget right now.) A good corded one would be about $150+. An air tool impact wrench can be got for about $75.
I have a 3.5 gallon, 135 psi pancake compressor. The tools I've looked up say that 90 psi is the ideal pressure and they use 5.5 cfm of air. Knowing nothing about air tools I am wondering if I could get by using my small compressor and an air impact wrench. Entire job is removing 4 wheels and then putting 4 on. I normally do this with a lug nut T wrench and the desire for an impact wrench is just pure laziness. It does not have to be fast.
Thanks for any advice.
/ Air tools w/ small compressor? #2
If you don't do it very often you will get by. The air compressor will run all the time and you will have to wait for it. Don't expect great perfromance from a $75 air impact, I'd spend a little more and get a good one.
/ Air tools w/ small compressor? #3
i sugest getting a 1/2" impact. forget the 3/8
to get one of the 'force' you need, and in your price range.. hit harbor freight.
luckilly.. impacts buzz a nut off fast.
you can probably get all the nuts off 1 wheel by the time the compressor is ready to charge up.
thus it will liekly charge up between each wheel.
I don't use impacts to put lug nuts on.
that's how you get broke studs...
also.. don't use theose wimpy coiled hoses. use a real hose with ID no smaller than the ID of the connector on the pump output.
Thanks guys. I've got good hoses. This is a job I do about 5 times a year, removing street tires and putting track tires on. Lugs go back on w/ light torque and then finished with torque wrench at about 100 lbs. I may give this a try. Really want a high end cordless one but that will have to wait.
/ Air tools w/ small compressor? #5
Don't cheap on an air impact gun, they generally require more CFM and wear out quite quickly and as well I have noticed that there is a good deal of slop in them and they may actually never break the lug nut loose once it starts showing some wear.
While the air compressor is filling up, I imagine with a pan-cake style air compressor you could actually run it out of air getting the lugs off. Just depends on how torqued the lug nuts are.
If I'm going to buy a good air impact gun, then I could probably just get a corded electric for about the same price and would not be limited by my puny air compressor. Tied to a cord/hose either way. I'll have to stew on this a bit.
/ Air tools w/ small compressor? #7
i guess this needs a YMMV.
I run pretty much all harbor freight guns. I work on tractors.
havn't worn a gun out yet.
my 12yr old 1/2" impact IR clone takes off tractor lug nuts fine.
my 3/4 and 1" gun will either take a nut / bolt off/out or wring it off.
i used to only own a pancake compressor.. I did tire lugs with it.
it peters out fast.. but then the nut gets broke loose in about 5 bangs.. then it is a freewheel.
yes.. the compressors's gonna be running for each tire.
ideal? heck no.. :)
buy a 200-300$$ IMPACT GUN? Why.. he has a 44$ compressor.. that would be futile.. :)
wait till he gets a 600$ compressor to get that spendy air tool.. :)
/ Air tools w/ small compressor? #8
remember.. this is tractorBUYnet.
most users here don't care about staying on budget when spending YOUR money. :)
some of us understand budget limitiations.
I'm sure we'd all like to own 100K$ of tools.. but when faced with work to do.. and a bufget of 50 bucks.. many of us understand that we may be faced with 2 choices. buy the cheap tool and do the work, knowing it's a cheap tool and won't last like an expensive one.. or NOT do the work because the designer luxory tool costs 180$.
clear choice. :) for some of us anyway. ;)
/ Air tools w/ small compressor? #9
I don't think your 3.5 gallon compressor has the volume to keep 90 PSI up for even one lug nut before kicking on. I have a 30 gallon tank and I wont get more than 3 or 4 nuts off without the compressor kicking on when it reaches 90 PSI. I can usually get all the nuts off without having to wait for the compressor to reach 130. For a big and stubborn nut like on my tractors rear tire, my 650 ft pound 3/4 drive HF impact does a good job but it uses a lot of air. The little Chicago Pneumatic 1/2" drive unit I have wont budge them or some automotive lug nuts either if they are very tight which is why I got the bigger drive unit. When I get some gorilla that tightened a lug nuts at the tire shop and when trying to get it off with the 4 way lug wrench and feel the shaft twisting a half round before the nut breaks loose, it isn't a pleasant feeling on my old bone wrist or back for that matter. Now I don't strain to get any nut off. It is coming off or break.
/ Air tools w/ small compressor? #10
Yea watch for sales especially with HF :)
I have an electric impact I barely ever use it. Its heavy and never seems to do the job for me.
I have a cheap impact gun I use with a 125 psi pancake compresser. Its even taken the engine nut off my Harley.
Sure you dont get alot of run time but it'll work its not the indy pits
Like its said use a good size dia hose to get plenty of air
/ Air tools w/ small compressor? #11
ideal? heck no.. :)
People are so touchy these days.
I didn't say buy the most expensive one out there? At least I can't find it in my post. If he had a $600 air compressor, he probably wouldn't need an expensive impact gun.
I only stating that a cheap air gun wouldn't probably be the best buy for the money. A little better air gun will have a little better performance especially on the a pan-cake style air-compressor. Pan-cakes don't store much air, don't build up air pressure quickly and a real cheap tool will probably not be able to get the work done. On an air compressor with a larger tank, may not be as big of an issue (just in case, I am not recommending buying a new air compressor, I don't need anymore flaming today). I have bought cheap tools, and most of them end up in the garbage after a few uses. I have also bought name brand tools that would've ended up in the garbage too but were saved by their warranty.
But case in point, I have had two sub $100 air guns from Sears that literally tore themselves a part after a couple months of easy use (not that Sears sells the best tools, just my experience). I had another (well it lasted a couple of years) that would try to turn the bolt but before it started started turning the bolt it would be cycling back for the next impact, end result the bolt never moved. I thought the bolt was stuck, I was amazed when my breaker bar slipped out of my hand and the lug nut spun just from gravity but the impact gun wouldn't turn it!
/ Air tools w/ small compressor? #12
A super cheapie cambell 1/2 I've abused and treated like **** is over 10 years old and going strong. For the use stated go cheap with confidence, especially harbor freight where you can swap it out if you get a dud.
/ Air tools w/ small compressor? #13
One reason I am recomending a better air tool is I have a cheaper air impact, and it doesn't get the job done. I have a bigger air compressor, and even with the air turned up to 100 psi, it often won't get lug nuts loose. The better one I have works well and I think its a Chicago Pnuematics.
/ Air tools w/ small compressor? #15
Same here, the wrench came as a package with the 8 gallon Campbell compressor along with paint gun and a ratchet. Cheapest thing you ever saw, paid for itself in no time. That thing even managed to loosen up nuts on tractor tires lol
/ Air tools w/ small compressor? #16
I assume you are refering about yourself then. I'm not getting bent out of shape.. just relating an opinion and a few real world experiences.
A little better air gun will have a little better performance..... ....... a real cheap tool will probably not be able to get the work done....... .......I have bought cheap tools, and most of them end up in the garbage after a few uses. ..........I have also bought name brand tools that would've ended up in the garbage too but were saved by their warranty.........
So far i see lots of conjecture and guessing about what a tool will or won't do.
all the OP has to do is read the side of the box for torque supplied and air used.
as for your sears that blew apart after a few trigger pulls? I guess that's a tick on the score card for the argument that higher price does not get you higher quality always.
I guess you had some bad experiences with the cheaper air tools you bought then threw away after a few uses.
I'm quite happy about mine. I've got a year of use almost on my 1" gun, and a few years on my 3/4, and at least 10+ on my cheap 1/2" and 3/8 drive. that 1/2 drive has a ton of 'miles' on it.... has served me well.
if any of them up to the 3/4 inch simply disappeared right now.. they have paid for themselves. the 1/2" alone may have paid for them all... a few times over. I watched and waited for sales, etc. have not paid over 100$ for any of my guns.. even the 1"er waited till it went on an advertised special and got it right. couldn't fully use it till i got a real compressor... the 3/4 I had worked over my 30g upright .. wasn't untill I bumped to a 60 that I could use the 1" though.
anyway.. that's why i added the YMMV tag on my post.
I've had fantastic results over a long period of time. you've had dismal results in realitively short periods ( high early failure rates ).
Statistically.. neither are correctly indicative of the actual products lifespan.. too small a sample population really.. )
/ Air tools w/ small compressor? #17
if the better one is a CE.. it's a cheapy too.
remember.. you have to compair apples to apples.
if you have 2 cheap 1/2" guns and one is a 125ft# and the other is a 200ft# the 200ft# is a stronger tool.. no matter how much air you have.
due tot he vast availability of tools at places like harbor freight.. you may see both of those guns at the same price or only dollars apart.
that's why you have to read the boxes and compare.
I've bought tools with better specs CHEAPER that tools with lesser specs at harbor freight... you really DO have to read the package....
They sell a 1" air gun that actually performs less than a higher end 3/4" gun they have... the 1" gun is more $$ go figure..
/ Air tools w/ small compressor? #18
What about the impact sockets you know I dont think I have a single USA made impact socket. There all imported all come from different places like Northern Tool, Homier, and HF. All seem to work fine but can break reducing adapters pretty regular. :)
Well, I had to do the job today and since I could not decide which way to go I went the super cheap route:
With the currently available power source it will rarely over torque a lug nut. It requires no electricity or battery power. It does run out of air pretty fast but it cycles back again after a few minutes. A cold beer helps. ;)
Seriously though, I typically like good tools and when it is a tool I am likely to use a lot, then I get a good one. (Having said that, I have never had a quality problem with a Craftsman hand tool. I've mangled some by neglect/accident. Replaced for free. There is a Sears about 4 miles from my house. No waiting for the Mac or Snap-On truck.)
However, I agree with Soundguy in regard to tools that I use infrequently to do jobs that are neither delicate or precise. And with my Scottish heritage, nothing delights me more than finding a good tool for a small amount of money. So sometimes I do have to suffer through a dud or two in that quest.
My situation is this: In my current house I have no garage. I have a dungeon-like shop in my basement but all automotive work occurs in my driveway. I have a car that I take to the track so whenever I go I have to change wheels and brakes. I could get a larger compressor but I'm just not sure that would make sense because it would hardly be used for anything else. Plus, there will come a time when I may need to do this work at the track where electricity may or may not be available. That is why I am interested in a cordless impact wrench. I've heard similar stories about them too. Hard to tell what you are getting. But again, virtually all it would be used for is lug nuts/ wheel changes. Maybe occasionally work on gates or deer stands around my property.
