Air Compressor
/ Air Compressor #51
I have a H.D. Husky 60 gallon in my shop . Does everything I want it to do and it is Quieter than any of those 3 gallon pancake compressors . Have multiple fittings coming off the 1" main pipe out of tank . 3/8" hose , 1/2" hose and 3/4" hose . 3/4" is for My 1" impact I use on My semi . At less than $500 , I have already got my monies worth out of it after 5 years and it is still running like a champ .
Fred H.
/ Air Compressor #52
GAD!
Three year old dead thread asking about medium sized compressors in the $600 range until
Whatever market trend sets rumours to harm Eaton products, it doesn't bother me , to choose my first choice regarding industrial compressor.
Am regular customer of Eaton Compressor & Fabrication, their 60 HP 3 Phase Dual Volt Rotary Screw Air Compressor working fine in my workshop.
From my side 3 thumbs to Eaton :thumbsup:
a first time poster decides to promote a $17,000 compressor.
Talk about mission creep.
Even for TBN this is overkill.
/ Air Compressor #53
The issue is that 2 stage hold their rated CFM to much higher pressure than 1 stage. ... 2 stage have a compression ration that is very high in relation to that of a 1 stage.
No matter what you do it boils down to motor power (provided that the pump is matched to it).
/ Air Compressor #54
Yes, but there are realistic limits imposed by flow issues at top dead center. ... A 2 stage has these too in each cylinder of the 2 stage pair. But when you consider that the 1st cyl supercharges the 2nd to about 60PSI you see some relaxation in the need for the very high CR requirement needed to output good pressure in a single stage. 130 PSI is well past the point of efficient single stage compression.
,,,,, My 5 HP Kellogg American is rated 20CFM @ 100, 18 @ 150, and 15 @250. These are not at the same RPM, but optimized for use of rated motor power at the subject delivery pressure. Throughout the range the compressor exhibits about 75% volumetric efficiency between displacement and delivery.
My Polar air does 17 cfm at 150 psi. Single stage 5 hp. Lower RPM than most and much quieter.
According to its specs that CFM delivery requires the max rated compressor rpm and it takes a 7.5 HP motor to do it. Volumetric efficiency is about 53%.
,,,,,,,,,,,,,Nope
/ Air Compressor #55
,,,,,,,,,,,,,Nope
16.5 cfm at 145 psi. see link for specs--https://www.eatoncompressor.com/piston-compressors/premium-vertical-piston-series-5-15hp/5hp%20Single%20Stage%20Industrial%20PLUS%20Series%20%20/5hp-2-cylinder-single-phase-80-gallon-vertical-air-compressor
/ Air Compressor #56
CFM 16.8 SCFM @ 145 PSI / 19 @ 100 PSI
Compressor Type Piston Electric
Description 5HP Single Stage Air Compressor
Factory Settings 145 PSI Shut off Max Pressure - Turn on 100 PSI
Low Oil Shut-off: No - Has Sightglass
Max Working PSI 145
Pump Material Solid Cast Iron
Pump model number APP2V0732S
Pump RPM 650
Pump Style Single Stage
Model PP05V080V1
Dimension: LxWxH 34" x 24" x 72"
Product Weight (Lbs) 650
Motor Information
Running HP 5 HP
Horse Power 5
Phase 1
Motor RPM 1750
Running AMP 24 AMP
Voltage 208/230 Volt AC
Start Up AMP 48 amp
Recommended Breaker 40 AMP
Tank Information
Size 80 Gall
/ Air Compressor #57
,,,,,,,,,,,,,Nope
Max Working PSI 145
Pump RPM 650
Model PP05V080V1
Motor Information
Running HP 5 HP
Horse Power 5
Phase 1
Motor RPM 1750
Running AMP 24 AMP
Start Up AMP 48 amp
Tank Information
Size 80 Gall
,,,,,,,Explanatory Details from the mfg:
5HP 2 Cylinder Single Stage Air Compressor Pump
/ Air Compressor #59
So the specs they gave me are wrong? what do you suggest my rating is?
After perusing the site I cant find enough continuity in the mfg info to say anything for sure. I did find that that compressor [APP2V0732S] is listed as a 7.5HP unit. Apparently it can be run at min speed with a 5HP motor. I couldnt find the bore and stroke so i dont know the nominal rpm at which it displaces the listed 32cfm spec - Iv been assuming its at the max rated rpm of 840. -- Then I see 680 rpm in the manual. :confused2:
Working from the 32cfm displacement and delivery cfm at 100 and 150 PSI I found 60 and 53% volumetric efficiencies respectively. With the spec numbers varying with each repetition it makes me think they are not all derived at the same compressor speed. This would prevent the accurate figuring of subject efficiency. ... Frustrating
/ Air Compressor #60
Thanks for trying.
So they lied about what my compressor puts out?
1042 (A60430)
1042 (A60430)
Giyi GY-DHC Quick Attach Forks (A60463)
Giyi GY-DHC Quick...
2008 FORD F-350 SUPER DUTY (A60736)
2008 FORD F-350...
Snap-On Southern Thunder Edition 24-drawer tool box (A61307)
Snap-On Southern...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A61307)
Neckover GL24-2-7K...
2008 Jeep Wrangler Unlimited 4X4 SUV (A59231)
2008 Jeep Wrangler...
