Air Compressor
/ Air Compressor #61
CFM 16.8 SCFM @ 145 PSI / 19 @ 100 PSI
Compressor Type Piston Electric
Description 5HP Single Stage Air Compressor
Factory Settings 145 PSI Shut off Max Pressure - Turn on 100 PSI
Low Oil Shut-off: No - Has Sightglass
Max Working PSI 145
Pump Material Solid Cast Iron
Pump model number APP2V0732S
Pump RPM 650
Pump Style Single Stage
Model PP05V080V1
Dimension: LxWxH 34" x 24" x 72"
Product Weight (Lbs) 650
Motor Information
Running HP 5 HP
Horse Power 5
Phase 1
Motor RPM 1750
Running AMP 24 AMP
Voltage 208/230 Volt AC
Start Up AMP 48 amp
Recommended Breaker 40 AMP
Tank Information
Size 80 Gall
Thanks for trying.
So they lied about what my compressor puts out?
Sorta. I think all claims are not under the same conditions. For instance - a 5HP motor will put out 7.5HP ... so maybe theyre doing that and have reported the wrong running amps. They havnt reported the compressor speed in the setup. - Whatever it is it will be near constant until the motor breaks sync due too much overload. Probably somewhere around 9HP or when it burns up whichever is 1st. There are just too many skew possibilities to choose from. :confused2:
,,,I would put more credence in the 19cfm at 100psi. Working against 150 PSI tank pressure single stage compression is only putting out a brief spit of air at the top of each compression stroke. This amounts to a huge brief flow and greater volumetric efficiency losses. -- The 16.8 figure is likely incorrect for the compressor rpm that pumped 19 at 100PSI
