Air Compressor WARNING!
/ Air Compressor WARNING! #41
Thing that kept going through my mind was: where did this happen? His speech/accent makes me think it was in the Northeast which makes me wonder if there was some salt in the air (from ocean or other salty body of water) that accelerated the corrosion....
That corrosive salt atmosphere that rusts things so fast in coastal areas diminishes the further inland a person goes, but it goes inland a lot farther than most people realize.... It's something I didn't learn until well into my current career and salt air corrosion at a location 70 miles inland was being discussed as being an issue.....
I thought about the salt too.
I am also thinking fatigue. Maybe it wasn't rolled accurately. So every pressurization cycle put stresses on it. Like an aircraft when finally the roof of the cabin blows off. I think rust would have caused a minor leak, like a water heater. That's (maybe) what I think.
/ Air Compressor WARNING! #43
I find it ironic that SCUBA tanks get annual inspections.
Small BBQ tanks have a 5 yr life and only take low pressure (like 10 lbs or so)
BUT shop compressors are exempt, which as we know can 'run away' to serious over pressuring and life threatening results.
Is OSHA sleeping here?
Perhaps regulating (monitoring) is simply too massive an undertaking and powers to be decided to let it be a 'self monitored' situation.
But then today they ask U to write up a 'quality assurance manuals' and then self police from there on in.
Considering safety warnings. I'm surprised that such tanks don't have warnings that suggest that they are never used indoors, but don't leave exposed to moisture either, not near any pets or humans and best not even to apply anything beyond normal atmospheric pressure. Because you guessed it, could result in Injury or DEATH!
/ Air Compressor WARNING! #45
The floor and trim guys have small compressor inside with quiet being a selling point... roofers use outdoor models.
ASTM option for tanks cost a little more but offer peace of mind...
/ Air Compressor WARNING! #46
Very timely, I just rewired and old compressor that could hold over 200 psi... once I got it cranked up, it popped a hole in the bottom (very low pressure). This tank sat in my basement for a long time (to be fixed). Finally got around to it and the hole happened... first thought was... it's cast iron, weld or braze?
Looking for a donor tank at the moment...
Proper term is a receiver.
/ Air Compressor WARNING! #48
:laughing:Yeah, for several years now, I just shear it all off as close as the clippers will cut it, but don't shave my head as some do.:laughing: My wife usually sees me start with the clippers and she finishes the job. She's afraid I'll miss some.:laughing:
Exactly what we do here.
/ Air Compressor WARNING! #49
I only skimmed the comments here, but did anyone notice that it looked like the drain was booger welded in? Not saying that's 100% what caused the failure, but the damage that heating the metal can cause, it could easily contribute.
DON'T WELD ON PRESSURE VESSELS.
Out in the shop today and happened to examine my HUSKY air pig. Seam also near bottom but not at bottom.
/ Air Compressor WARNING! #53
Another one that didn't watch the follow up video, and further more air tanks all tanks are welded together to begin with.......
I love that the guy talks about forensic airplane crash investigation. Then flicks the pressure safety valve a couple of times and calls it good, ruling that out. Maybe a job awaits him at the NTSB.
/ Air Compressor WARNING! #55
You didn't watch the follow up video then did you,,,,, and who the heck drains a tank every day and who the heck calls a tank a receiver, have you flipped your lid. I drain my vertical 60 gal tank two or three times a year, maybe a quart of water comes out, big deal little shuffle...........
I do, every evening when my employees go home and I shut off the screw compressor and drain the receiver, which is the proper name for the air containment vessel. Rest assured you 'tank' is rusting away inside on the bottom and at some point you will be unpleasantly surprised. Mine is a tad bigger than 60 gallon. More like 175 gallon. Bet you call an adjustable open end wrench a Crescent wrench as well......:laughing:
/ Air Compressor WARNING! #56
Nice. Looks like a typical 'blow your nose' weld job too.
/ Air Compressor WARNING! #57
My compressor with TANK is 8 years old, I might be surprised if I outlast it. I won that bet, been calling it an adjustable wrench for the past 50 years and if it slips off there are a few other names...
/ Air Compressor WARNING! #58
I’m well aware of that fact. I did skim the follow-up and saw that it split on the seam. That wasn’t the point of my post.
Most homeowners aren’t good enough welders to understand what heat does to metal. I’m a decent welder but won’t touch a pressure vessel. If you’re a boilermaker, welder by trade, etc... have at it. Otherwise, I stand by my statement- Don’t weld on pressure vessels.
You’re free to disagree.
Clearly, that guy sucks at welding, I was just pointing out another potential point of failure is all. ;)
Who knows of a catastophic compressor tank failure? I know of none personally. With millions of consumer grade compressors out there, and probably many neglected, what does that tell you?
/ Air Compressor WARNING! #60
They are built to be abused?
I've heard of more tires exploding than tanks. But the advice in this thread is sound. The maintenance protocols are there for a reason even if neglecting them doesn't cause failure all that often, you're playing with your life or somebody else's life.
John Deere 920 (A64126)
John Deere 920...
2019 PETERBILT PB337 LUBE TRUCK (A63276)
2019 PETERBILT...
Unverferth Perfecta 12 (A64126)
Unverferth...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
Gradall no crank no start (A61568)
Gradall no crank...
