Air Compressor WARNING!
/ Air Compressor WARNING!
I just got a new MIG gas bottle for my welder. Maybe four feet tall 10" in diameter. Had it ten years or more! I can't lift it on to the cart. Welding on handles seems like such an attractive prospect.
Kind of unreated. But the full replacement cylinder seemed a lot heavier than the empty one. Can gas be that heavy? Is it because it's compressed? Does a compressor tank weigh more when charged with air?
I always bought opened hardly used rattle paint cans at Habitat for a couple of bucks. I have dozens of them. TOTAL waste of money for few of them work after sitting for years once slightly used. So, at least I get some fun throwing them in the fire. Best thing is, the suspense of not knowig when, or even if, they will blow.
/ Air Compressor WARNING! #102
Who knows of a catastophic compressor tank failure? I know of none personally. With millions of consumer grade compressors out there, and probably many neglected, what does that tell you?
I will say one thing ,nobody tells you anything . Kevin .
When you think of all the factors that would have to come into alignment for an accident like that to happen.
/ Air Compressor WARNING! #105
Not really. Striking a lighter over a drum which had held flammable liquids is never a good idea.
Only suggest that it didn't sound like his job, and that fact that he used a lighter and not a flashlight and the explosive mixture was right.
Heard a day or so ago that if GASOLINE wasn't a motor fuel it would probably be outlawed. Friend once had a automobile gas tank on his front lawn, had water running in it from a garden hose. Tried repairing it with a torch and the thing blew up.
/ Air Compressor WARNING! #107
He's lucky that he didn't blow himself up.
I believe that it was around Christmas 1980 when a rookie salesman at the Chevrolet dealer down in Auburn was sent out back to help clean the garage. Tasked with filling a 55 gallon drum with water; he leaned out over it and lit his lighter to see how full it was. That was the last thing that he ever did. Supposedly that drum went up into the air and bounced off the 30 foot ceiling.
WOW, another one like me that do things without thinking, wonder what causes that. I've collected old 250 gal oil drums for scrap steel but I always so nervous of that first cut I always filled with water first, so far no bang.
/ Air Compressor WARNING! #108
When I use to lug my acet/oxy tanks to get refilled I made a handle out of a 1" thick x wide board. I first cut to length then a hole just big enough to slide over tank, then cut 2" around the hole then on one side where it was sticking out 6' I cut out a handle hole, big enough for my hand. Grabbing by the handle the hole would pinch against the tank resulting in being able to lift tank....
/ Air Compressor WARNING! #110
Compressor Question. I fixed my buddies dewalt compressor. It needed the pressure switch and i rebuilt the control valve, easy peasy.
It runs fine, gets up to about 200 lbs and shuts off. I have drained it.
If it just lays there, unused, about how long should it go before it cycles back on. I'm not sure but, i might have a leak.
I will go back and look but I'm curious , what is normal?
thx
/ Air Compressor WARNING! #111
thx
Hours if not days.
Depends on how leakproof it is.
Aaron Z
/ Air Compressor WARNING! #112
Very timely, I just rewired and old compressor that could hold over 200 psi... once I got it cranked up, it popped a hole in the bottom (very low pressure). This tank sat in my basement for a long time (to be fixed). Finally got around to it and the hole happened... first thought was... it's cast iron, weld or braze?
Looking for a donor tank at the moment...
I tried a tank repair experiment.
First: Put some OSPHO in the tank, and sloshed it around a bit, and let it sit for several days.
Then drained the OSPHO, and hooked the blower end of a vacuum to the tank with all tank fittings removed.
When I believed it to be dry, added a wet mix of two part marine epoxy to the tank, allowing the epoxy to lay in the bottom.
Waited a week,
Process worked.
The tank is still in use 5 years later
/ Air Compressor WARNING! #115
When you see the result of the valve on a large Oxygen cylinder break off; changes you perspective fast. when I went to welding shop at high school we had to change out cylinders on the manifold. Kid moved a full cylinder w/o the cap on. Lost control and it became a rocket. Went through a reinforced concrete block wall and destroyed the door on a parked car 20 feet away. Lucky he was behind it.
Ron
/ Air Compressor WARNING! #116
Hours if not days.
Aaron Z
Thx, that's what i thought. i fixed my friends but it only goes 1 hour before recycling, if left alone. i think i better rewrap all his old connections. better than nothing!
/ Air Compressor WARNING! #117
My compressor hardly loses air at all. What I did was buy quarter turn valves and install then by the quick couplers. That has saved considerable compressor cycling. I basically don't hear the compressor run unless I use air.
My compressor serves Five buildings. Every coupler has a small quarter turn valve. The losses otherwise would be unacceptable. Not to mention, once in a while an air hose blows which could leave the compressor running.
/ Air Compressor WARNING! #119
Good comment - more to see and learn here than everything else combined
/ Air Compressor WARNING! #120
An old spray bottle with a little dish soap and water sprayed on the connections after it pumps up should find any leaks.
Marcrest BSP449 (A64127)
Marcrest BSP449...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
2022 KUBOTA SVL75-2 SKID STEER (A65053)
2022 KUBOTA...
KUBOTA SVL97-2 SKID STEER (A62129)
KUBOTA SVL97-2...
Caterpillar TH255C Forklift (A63688)
Caterpillar TH255C...
