Air Compressor WARNING!
/ Air Compressor WARNING! #121
I bought an aluminum california air tools air compressor and love it. Its only a little lighter than steel, and i bleed it everytime, but I use mine all the time, and I like knowing that its not going to rust on me.
/ Air Compressor WARNING! #122
Those are nice looking little units!
/ Air Compressor WARNING! #123
/ Air Compressor WARNING! #124
/ Air Compressor WARNING! #125
^^^ Very Clever...
I can't imagine dumping all that air. And waiting twenty minutes if I need air to pump my five buiiding system back up again. I did think up ideas and got the stuff together for a timed solenoid valve, but never finished the project. Now, with my once again clogged drain, I wish I had.
/ Air Compressor WARNING! #127
If you are speaking of the solenoid valve it is not to dump the air from the tank but to disconnect the entire system from the tank. Tank stays full. Tank, solenoid valve, distribution piping.
Another benefit is when I come in I can hear if I have a small leak. If my hoses are tight with no leaks I just hear a click when I turn the lights on. If I hear the click then the hiss of air to fill the system I need to find the leak.
I have installed a system similar to this at our local volunteer fire station but rather then control it by a light switch I control it with a radio. When the radio "hears" that particular fire station's radio code the receiver closes a set of contacts which activate a Delay On Release timer. This DOR timer controls the solenoid valve allowing air to move from the compressor to the apparatus' air brake systems. After three minutes it automatically closes the valve. With this system when the volunteer station receives a 911 call, the trucks are filled and ready to roll when the volunteers arrive minutes later and open the door. Prior to that the compressor was "hot" to the rigs all the time and we had issues with water in the tanks.
Thirty and 40 year old fire engines can have a lot of minor leaks and the yellow coil umbilical hoses can separate causing compressors to run till they die with no one there to hear them.
I must say, I like your way of thinking beyond the "norm". I was also going to put a timer on my compressor that if it did run for too long it would shut down. Another project that never happened! I think my compressor is rated for 100% continuous duty, but that's not the point.
/ Air Compressor WARNING! #129
Your electric bill.... Not mine.
/ Air Compressor WARNING! #130
I had a 8 gallons compressor that was stolen in 2012 so I bought a new one then. The old one, I would drain after every use (plug was easy access) but the new one, I never drained it, thinking I only use it a few times a year anyway. Boy, was I wrong. Reading this thread, I went ahead and drained it. Here's what came out of it 😧
Lets say I'll drain it more often now...
/ Air Compressor WARNING! #131
Looks like it's in the kitchen. Hope no one mistakes it for gravy
I just had an issue with my drain valve. Seems it wouldn't close, but my compressor never generally has the pressure totally depleted and for some reason, it had, and when I went to turn it on, air was coming out the vent pipe, out the side of my barn. Long story short, I had installed (but not remembered) an AUTO drain, but it is of no use since it only works when the pressure is nearly nothing. It has a manual knob that I use once or twice a year, but no indication it auto evacuates.
/ Air Compressor WARNING! #134
Well, I've never changed the oil in the pump since I have it (2012). The eyelit was showing a dark color while the manual states 100% synthetic 5W30 oil. I drained it last night, looks like it was passed its prime...
/ Air Compressor WARNING! #135
Usually, a clogged condensate drain indicates the receiver is rusting inside and as it rusts, the receiver gets thinner and at some point...BOOM.
/ Air Compressor WARNING! #136
I drain mine occasionally after reading a comp thread. Some of the stuff in these threads that pass doer fact is a bit wonky. A bit like some engine oil thread,,, I did this and 2 years later it is all good so what I did is correct etc.
I about blew myself up when I was a kid with some of the stuff I built, more than once and its scary to think about and I go thru it with my kids when I have a chance. But I work with air all my life in a lot of places and never seen it and only a couple places on the net and the pic gets passed around like the flu. 5 ounces of water is different than 5 gallons and even that may not matter, the tank is never really dry anyway.
The failures of auto drain type things however are numerous and some of the reasoning behind it is just as faulty and no promise of great performance.
I am not sure at what point I will test my stuff, its all old. I am a fan of vertical tanks however, seems it cant be great to have condensate lay across the bottom. Having said that my 1972 has been on constant, had 1 crack on a motor mount. Its been well abused.
Also have multiple buildings, tied 3 vessels together with some left over tubing to make a common drain. I kick the valves on occasion when a thread like this comes up. The little red we got at sale for 50$. Was really a liability, had to fix every piece on it except for the motor itself. Ran for a few minutes, all was well till we put it to work, someone had glues a hole in the tank where the wheel brace was welded on. Cost me time when I needed it, would have been cheaper to buy new.
2011 New Holland HT154 Rake (A63688)
2011 New Holland...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
Landhonor RGB-11-72, 72" Rock Grapple  (A62679)
Landhonor...
2012 Peterbilt 337 G and H 8000 Container Handler Truck (A64194)
2012 Peterbilt 337...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2022 EZ-GO ELITE...
