air compressor problem
   / air compressor problem #11
Ron, that is what I was going to suggest, until I Goggled the Kobalt, if he has the same type, he may have a problem (if a 1 piece cast manifold). If he can get the regulator "all open", then just install the shutoff "down stream" or at the outflow port.
   / air compressor problem #12
If your that cheap, eliminate the regulator and put on a ball valve. The compressor must have a high pressure shut off switch to shut off the motor.
If all your doing is filling tires, a tire gauge can be your regulator. Should be anyway, as the gauges on cheap regulators are usually not too accurate.
What he said.^
You don't need a regulator for the uses you mentioned.
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
378721 (A54865)
378721 (A54865)
2014 VOLVO EW210D MOBILE EXCAVATOR (A60429)
2014 VOLVO EW210D...
TANK MANIFOLD (A58214)
INTERNATIONAL FLAT BED TRUCK (A52707)
INTERNATIONAL FLAT...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
