Tires Ag vs. Industrial tires?
   / Ag vs. Industrial tires? #21
Radman, I wish I could agree with you on that last sentence....I run my front R-1s at 4-6 psi above max rated, and still have sidewall flexing issues with a full bucket of dirt. I recall a TBN member a while back saying there is a R-1 tire with the heavier R-4 sidewall. Seems like a good answer.
I agree, I still have flex/squish and also run mine above the psi. However, I don't feel too worried about rolling the tire off the rim at the higher psi. The R4s definitely do better under heavy FEL loads.
I have a JD 4520 with the hydraulic psi turned up from 2500 to 2800. I frequently max out the loader and flatten the front R1s by 25-30%. Just the nature of less stiff side walls with R1. Our ag tractor and FEL has radial R1 tires and those even seem to flex more under heavy loads.
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
Deere 35G (A53317)
Deere 35G (A53317)
1999 GMC C7500 S/A Dump Truck (A59230)
1999 GMC C7500 S/A...
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
